Flood after sitting 5 hours
Old May 12, 2026 | 06:40 PM
Radovette's Avatar
Radovette
Default Flood after sitting 5 hours
1978 L48 bone stock except recurved distributor per Lars timing papers. Usual hard starting when sitting for several days. (Need to put in a windowless needle seat I suspect).I drive to my volunteer job and it sits for about 5 hours before returning home.
In wintertime in Colorado it will crank right up with maybe half to no accelerator pedal.
Lately in warmer Springtime temps it grinds and will not catch. Pulling the air cleaner reveals very gassy rich fumes. So I let it sit and hope it clears. Try again holding pedal wide open. Grind grind grind. No start . A quick shot of ether brings it to life on first revolution.
I rebuilt the Qjet ( a year appropriate service replacement) about 4 years ago and it has been great until this Spring. Strong squirts from accel pump jets.
Not sure where to start looking. Float level?
Old May 12, 2026 | 08:52 PM
MelWff's Avatar
MelWff
Unless you fully depress the gas pedal at least once on a totally cold engine the choke and fast idle function will not completely engage.
Have you checked the choke adjustment on a cold engine?
At air temperature of 72 the choke should barely close completely.
What did you set the float level to when you rebuilt the carburetor?
Old May 12, 2026 | 08:55 PM
OMF's Avatar
OMF
This is what I think is going on.....
The hard starting after a few days could be just a dry floatbowl.....I've read that when the engine has just been shutdown it heats the fuel up to the point where it gasses off and evaporates 1/2 the bowl capacity in just a couple of hours. The rest just evaporates.
In wintertime in Colorado it will crank right up with maybe half to no accelerator pedal. That's because the choke is doing it's job
A quick shot of ether brings it to life on first revolution. This to me says it needs a few pumps of the gas pedal prior to starting to get some fuel in the intake.
Old May 12, 2026 | 09:03 PM
socal_tom's Avatar
socal_tom
Yes the problem is with your rebuild, Get Lars to do it he has a very good rep
Old May 15, 2026 | 06:49 PM
Radovette's Avatar
Radovette
Melwilf-i set the float to 15/32” and the choke of to 2 lean. Pics show the choke before and after on a cold engine at 70*F
Choke after pedal depress
Choke before pedal depress
Old May 15, 2026 | 07:52 PM
Piersonpie's Avatar
Piersonpie
Looks pretty normal.
The way to actually see how much the choke is opening when the car is on high idle will require removing the air cleaner and pushing the choke pulloff all the way in.
Old May 15, 2026 | 08:44 PM
MelWff's Avatar
MelWff
I think you need Lars paper on tuning a Quadrajet, float level sounds high and if you have a window seat that contributes to the problem.
Old May 16, 2026 | 10:21 AM
pltmgr's Avatar
pltmgr
After a few days I believe the gas has evaporated from the carb. I prime my carbs thru the air horn in a situation like this.
Im guessing the 5 hour situation may be from gas boiling/evaporating in your carb. The area gas companies probably haven't switched from winter formula yet and the increased temps are causing your problem. I had a vehicle that ran great in the winter, had problems in the spring, then ran great again in the summer.
Old May 16, 2026 | 02:29 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Make sure the choke partially opens when cranking it. My car used to flood out when it was cold because the choke pull off vacuum diaphragm wasn’t opening the choke plate when cranking it. I think it is supposed to open 1/4 inch when when you are starting it when cold.
Old May 17, 2026 | 06:33 AM
KENS80V's Avatar
KENS80V
I think post #9 nailed it!
Put a vacuum tester on the diaphragm to see if it holds vacuum. If it bleeds down then you have found your problem. While you're in there with the vacuum tester.....put it on the HEI diaphragm as well.
Old May 20, 2026 | 01:43 PM
Radovette's Avatar
Radovette
KENS80V- I pulled the choke vacuum break and tested it. Will hold vacuum and has the required slow rate relaxation rate when vac is disconnected. I read one of Lars’ rebuild threads and will set float to 0,300” when I open it up once I get some parts from Cliff Ruggles.(float/needle /seat Thanks everyone for the help and suggestions. I will report back after the new parts go in.
Old Jun 11, 2026 | 07:11 PM
Radovette's Avatar
Radovette
Default Update
Installed Ruggles’ needle/seat/float/air horn gasket. Runs really nice at idle. Will give it a good heat soak next week and see what happens after sitting 5 hours.
Old Jun 18, 2026 | 05:19 PM
Radovette's Avatar
Radovette
Default Update from OP
Checked on the choke flap opening with full vacuum on the pull off. Was OK. Let it sit 5 hrs after a long drive this morning. Initial start sequence got a sputter but no run. Gave it half a pedal and started right up. The Lars distributor recurve also solved a hesitation from dead stop. Thanks for all the help.
Old Jun 18, 2026 | 09:37 PM
MelWff's Avatar
MelWff
Did you check before initial start if the choke closed all the way after one complete depression of the pedal?
Have you adjusted the choke fast idle ?
Old Jun 19, 2026 | 09:28 AM
Bob3700's Avatar
Bob3700
Have u looked at the plugs in the bottom of the carb? These plugs are there for manufacturing ( drilling passageways). Once the drilling is complete the passages are plugged. Often, with age the plugs will leak n drain the float bowl. Sealing these plugs solves the float bowl leaking issue.
To Flood after sitting 5 hours
