LS3 dry sump convertion ?
Old Today | 03:34 AM
Cobra4271234's Avatar
Cobra4271234
Default LS3 dry sump convertion ?
Hello!
my LS3 setup has an oilpan of the LS7 I think, internal pump installed.
as I found out the two connectors on the pan are without any direction, just connecting to the oil reservoir?
so it is pressure less? that means the oil is just an outside reservoir to hold the level ?
that would further mean, the tank must be placed, that the engine gets oil and not overfilles? level inside tank = level inside engine?
Thanks in advance!
Old Today | 03:48 AM
Cobra4271234
demounted the screw connector on the pan, there are channels, not only a stupid connection to the pan. I think they are connected to the pump.
which one will suck and press ?
now, can I mount the reservoir anywhere? I do have a Aviad tank to it, input up, output down.
channels going to the front
Old Today | 04:01 AM
Cobra4271234
found GM number. GM 12605528
could anyone pls look on the GM number? what is it and how does it work? Thx!
Old Today | 04:14 AM
Cobra4271234
OK, found
both connections go to the pump. Which one should be connected to the reservoir up and down?
is it neccessary to mount the reservoir on a certain hight to the engine?
THX
Old Today | 09:34 AM
Cobra4271234
with this hopeful correct info the connection is clear
still I do not know the mounting height of the Reservoir, does it matter ?
Old Today | 02:02 PM
davidfarmer's Avatar
davidfarmer
you seem to have answered your own questions, but does this engine have the dry-sump crankshaft and pump installed or just the wrong pan?
Old Today | 02:06 PM
Cobra4271234
engine is build for dry sump
still the question of the mounting position of the Tank to the engine
To LS3 dry sump convertion ?
