C1242 codes and parasitic draw on battery
Old Yesterday | 08:19 AM
Jims2001's Avatar
Jims2001
Default C1214 codes and parasitic draw on battery
Having ABS traction control light that I fixed 10-12 years ago, plan to remove and fix again. But now battery doesn't hold a charge overnight. Charge to 12.5-13.5 volts goes down to 6 volts by morning. That is with the ABS module disconnected. Could both problems be connected?
Old Yesterday | 02:45 PM
helga203's Avatar
helga203
Get the battery load tested. Don't care if it's new. Get it tested
Old Yesterday | 04:24 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Well if the EBCM is disconnected and you still have a draw it's not the EBCM...do you know how to perform a parasitic drain check ??...if not seek out an auto electric shop in your area.
To C1242 codes and parasitic draw on battery
