[C2] Replacing the OEM engine block coolant drain plugs with brass petcocks
I know DZauto replaces all the OEM drain plugs with brass petcocks, but has anyone replaced their OEM drain plugs with this style of drain plug?
Live well,
SJW
If you flush your engine block, and after that use and maintain good coolant (like Zerex G-05) you should never have to use these plugs again in your lifetime. But if you do, the anti-seize used above will allow easy removal.
Larry
