Need some help with T- top and door clips
This is where the material is torn out
This is where the clip goes
This is how it is supposed to look
This is how the clip attaches to the panel
Damaged door panel clip area. The cardboard is torn and won’t support the clip.
Another damaged clip location.
Reinforcements being cut from 22 gauge steel.
Initial trim of steel reinforcement and layout.
Detail of front and rear reinforcements.
Exposed side of door panel showing foam and cardboard.
Foam is separated from cardboard with a razor blade. The reinforcement is then inserted in the slit and epoxied in place.
Missing cardboard is replaced. This is simply for cosmetic reasons as the steel reinforcement will provide all of the support for the clip.
Steel reinforcement has been inserted and epoxied. Clip is installed for mock up… It will never pull through again!
Rear clip mocked up… Perfect fit! Damaged velcro clips have also been replaced as necessary. Original velcro clips work perfectly; reproductions do not.
Fact is, as long as the cardboard isn’t severely warped, you can generally save a door panel in spite of any damage it may have suffered.
Regards,
Stan Falenski
