I have an autoX toy C5 and I'm trying to get the back lower. I took a turn and a half out of the rear bolts, but I'm wondering if I can get more. It's getting a little sketchy though.
I think the top of the threads are just about at the top of the nut, but I noticed that the nut isn't actually threaded all the way - the top is actually beveled inwards.
What's the peanut gallery think? Is this as far down as I can go?
NHRA specs for lug nuts is that the diameter of the stud much project into the nut. Seems like a good rule of thumb.
IMHO you can get a rear lowering kit for $60 - it's not worth taking a risk https://www.westcoastcorvette.com/pr...97-2004-c5-z06
Yeah, you can find bolts for cheaper, but having all of the bushings etc in one spot sure makes this easy.
Based on the pics you posted, I wouldn't go much further. You MIGHT be able to get away with another quarter turn MAX, and a quarter turn wouldn't really lower you enough to be worth the risk in my opinion. If your class allows it, coilovers would definitely get you lower.
5 threads closest to the nut/hole in any length bolt effectively hold all the tension.
"Each thread will hold half of what the first thread holds. So one thread will hold 100% of the weight if one is engaged. When two is engaged first thread holds 66,6% of the weight and second holds 33,3% of the weight
At three threads the loading is 58% and 28% and 14%.
Adding more will converge to the point where first holds 50% and the rest is spread out."
