[C2] Wire under the dash
1. where does the green wire coming out of the steering column for the connect. I can’t remember
2. I have a white wire by itself with a female spade connector , not sure where it goes.
3. There is also a brown wire with a female spade lug.
I have attached three images.
thank you in advance
I uploaded a 1963 Wiring Diagram, see attached.
Your 1st photo... You're saying that's a White wire?
Your 2nd photo... Heavy gauge Brown. Is the ACC wire which goes to a Radio Capacitor mounted behind the Ignition Switch. This wire will have 12v in RUN or ACC. If cap is missing, just tape off the connector.
Mating connector on Cap is missing on mine.
Your 3rd photo... Looks like Tan, with the clip on the vent cable. That is the Horn wire going to the bulkhead connector, then out to the horn relay. The Green can be checked to see if it's from the Horn button by using your ohmmeter, one lead to gnd, other lead to green. Push the horn button and meter should show continuity to gnd. If so, connect those 2 together. FYI, The horn button wire color can be green or black in 1963 based on build date iirc. My Feb '63 coupe was black.
If your green isn't the horn button it may be for the Park Brake Alarm switch.
1963 w/green wire
1963 left w/ black wire, 56-62 right
