ride height adjuster remove or disconnect?
Old Yesterday | 08:31 AM
boonie c4's Avatar
boonie c4
Default ride height adjuster remove or disconnect?
I'm in the process of replacing my magnetic shocks on my 2012 G.S. Corvette @34K with Bilstein B8 shocks, I've purchased the Casper Electronic RTD Module inserts but regarding the ride height adjuster would I be better off just removing the device? Also will I have to readjust the height?
thanks for your attention boonie
Old Yesterday | 08:38 AM
dr_gallup's Avatar
dr_gallup
The ride height adjusters are a simple mechanical screw. You can't eliminate them unless you go to coil over shock springs in which case you completely remove the transverse leaf springs.
I would certainly check ride height, it may need to be adjusted.
Old Yesterday | 11:08 PM
kjchristopher's Avatar
kjchristopher
FYI, the springs on the magnaride suspensions are usually softer than standard as the system uses the shocks to firm it up when in sportier modes. If you didn't also swap springs, you now have a softly sprung Grand Sport.
To ride height adjuster remove or disconnect?
