18 by 8' wheels
They cost about $85.00 plus shipping. IMCO money well spent. Custom wheels are expensive. Might as well try to get it right the 1st time.
If you're going to go with a 2 piece wheel you can ask the company to send you the wheel before it's welded together. You bolt on the center section and position the hoop in the best possible backspace. Mark the hope and send it back to be welded in place. That just about assures the backspace is correct for your car.
Good luk going forward.
Besides are you speaking from actual experience or just trying to contradict me?
Do I have to go back and pull up the post that has the quote from VanSteel?
Or can you finally take my word for it as it's from actual experience.
Ya, go ahead and pull up the post and quote from Vansteel.
https://blog.vansteel.com/2025/01/of...trailing-arms/
At least I provided proof that's contrary to what you're saying.
Where's your proof?
Where's your proof?
Now can we get back to being helpful instead of contradictory.
Thank you.
Now can we get back to furthering the thread?
That's not proof; there's hearsay.
I want DOCUMENTED PROOF that with 18" wheels that offset trailing arms will not have ANY WHATSOEVER benefit over stock arms.
Otherwise, why would anyone buy those offset arms?
All the literature that Vansteel put out (that I referenced) makes NO MENTION that 18" wheels will negate the benefits of offset trailing arms.
Offsets vs Factory Trailing Arms
65-82 Corvette rear trailing arms and how offset t-arms work.Our standard offsets and coilover t-arms offer 2″ of additional backspacing for aftermarket wheels. By moving the parking brake bracket to the top of the arm we gain one Inch, then we offset the entire t-arm between the pivot mount and the bearing mounting surface another inch for max wheel and tire clearance of an additional 2″ over factory trailing arms. The bearing assembly, camber/strut rod, and half shafts remain in the factory location.
These arms are also stronger than factory arm and can’t hold water/moisture like factory arms where they are prone to rusting from the inside-out. Our bearing pivot mount reduces binding in the system which allows for better ride on the street and better handling for the track. Finally, the bearing is held in by a snap ring so it is easily replaced if it wears out. For max wheel and tire clearance, we suggest converting to coilovers which eliminates any leaf spring clearance issues. With our standard offset trailing arms, you may need a shortened composite spring to clear your new wheel and tire package. See our wheel and tire chart for C2 and C3 Vette size options.
Please point it out to me.
Your can call the quote hearsay and continue to insult me if it makes you feel better.
As I previously stated I'm speaking from experience.
You're calling me a liar. I'm here to share and learn.
You can disagree without insulting me,
That's up to you.
