I was told today that today by the Corvette concierge that my Grand Sport order is currently at production event code 3300 having advanced from 3000 on Monday, they were however unable to see a target production week. I would like to know if anyone else at 3300 has found a production week from any source? From what I have been able to find it appears that 2027 production may start somewhere in mid June.
Thanks
Did you call the concierge? My salesman isn’t the most communicative. Maybe I should try that.
Just called the concierge . They gave me a lower event code than my dealer and said all coupes are currently on constraint. Are you guys building HTC's? Or did I get someone that doesn't know what they are talking about on the phone?
i saw the coupe appearance package was on constraint. What code did they give you when you called?
Guess she wasn't wrong then. She told me 1100, but my last update from my dealer on 5/4 said I was at 2050. She said the dealer would have a more accurate reading of what event code I was at, but that coupes are on constraint until 6/8 so my status probably won't update till then.
As I mentioned in my post the concierge told me yesterday that my order was currently at 3300. My order for a HTC was submitted as part of the first allocations on 4/16.
Thanks. I guess I'll just call my dealer Monday. I didn't opt for the coupe appearance package either. Just double checked my order.
1100 and 2000 are basically the same. Neither mean anything until your dealer gets an allocation and ties your order to it. Then it will show up as 3000+.
1100 simply means your order has been put into the GM order bank, but with out an allocation it doesn't move any further.
2000 Means the vehicle is in the GM order bank via a dealer using their allocation with no constraints for it, and GM just accepted their allocated order.
Status 1100 (Preliminary Order): Anyone can sit at this stage indefinitely. It simply means the dealer typed your desired options into the GM Order Workbench. It does not mean the dealer has an allocation or that GM has agreed to build the car.
Status 2000 (Accepted by GM): This is the first major milestone. Your order cannot bridge the gap from 1100 to 2000 unless the dealer matches it to an active, unconstrained allocation during GM's weekly ordering cycle.
I'm in the process in talking to a local dealership in southern California re 2027 GS. I'm waiting for them to get back to me with a preliminary "order" for my perusal. I'm getting excited. But mid June production. I was hoping for an earlier production date.
Did you mean mid-July? Mid June would be the first production run expected to start the week of June 8th.
Someone on the forum said mid June. That's where I received the data.
Ah, ok. Let us know what your dealer says when your order is confirmed. I don't have a production date yet unless it just hasn't been communicated to me.
