C8 ERay/GSX/ZR1X ERay/GSX/ZR1X Discussion
Sponsored by: Vibe Motorsports
Does your PPF bumper have spliced seams?
Old May 15, 2026 | 12:05 PM
REDCON1's Avatar
REDCON1
Default Does your PPF bumper have spliced seams?
Got my Eray ceramic coated with PPF for front bumper/hood/headlights. Because of the angles of the front bumper, they told me there would be seams in places the PPF couldn't be stretched. They did a pretty good job on the bumper but was a little bummed to see a small gap at the center point of the front bumper (below the flags). I guess it would help if I had a pic but the car is at home right now. I was told that is how the computer cuts the film. Just wondering if all PPF bumpers are cut this way. The attached photo is pre PPF but the yellow lines show the area I"m talking about. The gap is about 1/8 inch in size.
Old May 16, 2026 | 10:24 AM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
No but there are different levels of installers
Old May 16, 2026 | 11:22 AM
QuickSilver20's Avatar
QuickSilver20
That would really bother me and from what I’ve seen it’s not normal. As mentioned above it all comes down to how it’s installed. If that’s the primary point I would imagine possibly starting there and working out would have corrected it.
I think another thing to factor in is I imagine they used a pre cut piece of material. It all comes down to price and how much time they spend to get it perfect. But I’d be upset if that’s how the piece is intended to lay based on design and they didn’t communicate it to me beforehand.
Old May 16, 2026 | 06:21 PM
planojoe's Avatar
planojoe
No seam anywhere on the car.
Old May 16, 2026 | 07:01 PM
BuckySti's Avatar
BuckySti
I’ll check mine out tomorrow and see, but I don’t remember anything like that.
Old May 16, 2026 | 10:33 PM
ahalachis's Avatar
ahalachis
I can’t see what you are talking about in the pic you posted but I don't have a seam in that location. Like mentioned, a lot of places use the mfg software and a plotter that will pre-cut the sheet of PPF, the software allows the installer to make adjustments, for example, they can set it to be long enough to “wrap” the edge or not, or adjust relief cuts…. I always recommend that you do a walk through with the installer the "day of” and make sure you understand exactly how they will tackle the installation, especially the “tricky” parts.
If you are not happy you should go back and talk to them, a good installer will redo it if you are not happy...
Old May 17, 2026 | 09:05 AM
Joe's Eray's Avatar
Joe's Eray
That would bother the heck out of me if they did a PPF job like that on my car. Sorry to hear that they did this to your car.
Old May 17, 2026 | 12:04 PM
REDCON1's Avatar
REDCON1
This is what I'm talking about.
Old May 17, 2026 | 08:02 PM
ahalachis's Avatar
ahalachis
Ok, that seam should be underneath the point of the nose completely out of site, looks like they didn't place the PPF correctly on the bumper or they elongated the relief cut. Either way it is not right. If it is a Xpel shop I would take it back and ask them to redo it. But before you do that look the whole install over and make notes of what does not meet your satisfaction and bring them the list to review. If they give you push back call the Xpel customer service…(assuming they are a certified Xpel installer)…they will make sure that shop stands behind the installation.
Xpel Customer Servive
1 (210) 678-3700
1 (800) 447-9928
Edit: Now that I am lookin at the pic more closely, they placed the precut PPF sheet incorrectly (too far up on the bumper) I can see the edge running along the bumper, that is supposed to be wrapped under the bumper like a 1/2”… That is a incorrect installation…take it back.
Old May 17, 2026 | 09:36 PM
Q Pilot's Avatar
Q Pilot
Totally unsat. No seam there on my PPF job. Take it back.
Old May 17, 2026 | 11:08 PM
Matthewstorm's Avatar
Matthewstorm
Holy crap that is a bad job. I'd be Hella pissed.
Old May 18, 2026 | 08:05 AM
ghostwriter's Avatar
ghostwriter
2nd Gear
I had a similar experience when I got PPF installed on my front bumper, and from what I learned, small seams or tiny gaps are actually pretty common on bumpers with sharp curves and complex shapes. Installers usually use computer-cut templates, and sometimes they intentionally leave a slight gap rather than overstretching the film, which can lead to lifting later on. A 1/8-inch gap around the center section doesn’t sound unusual, especially in a difficult area below the flags. Honestly, if the edges are clean and the film is sitting smoothly, that’s usually considered a solid install. Full-body coverage examples like ppf-wrap also show how complicated bumper sections can be handled in separate pieces.
Old May 19, 2026 | 12:23 PM
thebishman's Avatar
thebishman
I’ve had multiple cars including those with complex contours covered with PPF, and the above install is NOT a “solid install”; far from it. It either shows that the installer was in a massive hurry and chose to apply a pre-cut piece in haste, or simply has such a poor skill set that they shouldn’t be applying PPF, period.
Old May 19, 2026 | 04:49 PM
REDCON1's Avatar
REDCON1
In my area, there's really only one detail shop that does PPF/ceramic coating. I really didn't have much of a choice as I did not want to drive to the next location which was about 125 miles from my home, and for this installation, they kept my car for two nights. A friend of mine got his Eray PPF'd in a larger city (about 125miles away) and his bumper looks exactly like mine. When he sent me his photo's, I thought it was the norm. But having seen several youtube videos of ppf installation, none appeared to have the open slit at the nose of the bumper. I will see how this ppf performs, and may have it removed later. I guess I can only fault myself for getting this done; they did tell me that they use computer generated pre-cut ppf sheets. Can't remember the PPF brand name but I do know it is not Xpel.
Old May 20, 2026 | 12:00 AM
24/Eray's Avatar
24/Eray
Not that i dont believe the rest of you guys but only one person posted the Pic and there is a huge relief cut.
Can you guys take that same super hi def close up of "your" ppf'd bumper. I'm curious now myself?
Old May 20, 2026 | 12:16 AM
Q Pilot's Avatar
Q Pilot
Here’s my front beak fully PPF. I just blew up a current picture but I think it shows good enough.
Old May 20, 2026 | 10:10 PM
ahalachis's Avatar
ahalachis
I will in the morning
Edit: This should be good
To Does your PPF bumper have spliced seams?
Old May 21, 2026 | 12:18 PM
planojoe's Avatar
planojoe
Here's a pic of mine
Old May 23, 2026 | 11:30 AM
24/Eray's Avatar
24/Eray
So a relief cut but matched up perfectly?
Old May 23, 2026 | 11:31 AM
24/Eray's Avatar
24/Eray
Bad angle and low light. Is there a seam there at all?
