Whats the trick to fitting a Katech 103mm?
Old May 17, 2026 | 12:44 AM
Damnit, Laverty's Avatar
Damnit, Laverty
Default Whats the trick to fitting a Katech 103mm?
Put my MSD Airforce on today, and when I went to bolt up the Katech 103mm, I couldnt get a second bolt in- the TB seems to be hitting a standoff on top of the water pump, circled below. Nobody's ever mentioned having to trim the water pump, so what am I doing wrong? Help!
Old May 17, 2026 | 03:31 PM
Damnit, Laverty
Why do I even have a standoff there? Part number checks out, but the appearance doesn’t!
Old May 20, 2026 | 10:26 AM
smitty2919's Avatar
smitty2919
I can't help with the TB install but your flex fuel sensor bracket/setup intrigued me...
Willing to share details/photos on it? I have a similar Amazon sensor "saddle" bracket then I see you bent some aluminum to mount somewhere? Also what PN is that secondary braided flex line?
Amazon Amazon
I have the Lethal Garage kit and I'm not happy how it fits and rests in the engine bay.
Old May 20, 2026 | 11:29 AM
Damnit, Laverty
https://www.amazon.com/dp/B0FCM352WB...fed_asin_title
I have the Lethal Garage kit as well (and that's the line they gave me), and I objected to having a piece of the fuel system free floating. It's literally just a couple aluminum Z I bent as a temporary solution- but as we all know there's no fix more permanent than a temporary one.
I'll get you some closer pics in a bit!
Old May 20, 2026 | 12:26 PM
Damnit, Laverty
Here’s how much I had to trim the water pump, just in case someone else runs into the problem:
Old May 20, 2026 | 12:29 PM
Damnit, Laverty
Heres my lazy bracket. Held together with the countersink screws it came with, held to the motor with M6x1.0 bolts.
Old May 20, 2026 | 02:04 PM
smitty2919's Avatar
smitty2919
Perfect thank you!!! I'm trying to get mine better looking while still having the coil covers on. Right now mine is zip tied to that black plastic vacuum line
You already ground down the WP....I guess another option was to notch the TB? Does it have enough meat to notch it around the WP?
Old May 20, 2026 | 04:20 PM
Damnit, Laverty
Maybe? But I'd rather notch a 150 or so dollar water pump housing that I can replace on eBay than a 700 dollar throttle body that I can't.
As for the coil cover, why not insert two rivnuts in the plastic and bolt that bracket thru them? Again, cheap parts, replaceable easy if you revert later.
Old May 20, 2026 | 06:53 PM
Cordes Performance Racing's Avatar
Supporting Vendor
2014 cars have to notch that area on the waterpump. The 15+ cars do not have that standoff.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old May 20, 2026 | 07:12 PM
Damnit, Laverty
It’s wild that I never saw mention of it, and only one person in a random FB thread that brought it up once when I made the robots search deeper for me. Easy enough fix, just always nerve wracking to pitch aluminum bits everywhere around an open motor.
Old May 21, 2026 | 02:54 PM
smitty2919's Avatar
smitty2919
Good suggestion. I'll see what I can come up with for that.
Old May 21, 2026 | 03:47 PM
Damnit, Laverty
I have one of these from some completely different alphabet brand. For ~30 bucks, I've used it a surprising amount of times. The last time was to build a catch-can mount in my daily. I use it on motorcycle stuff... no affiliation with seller, but yeah. simple cheap tool.
Amazon Amazon
Old May 23, 2026 | 09:33 AM
Catfish4818's Avatar
Catfish4818
Haha! So True! That phrase is Benjamin Franklin- or Mark Twain-level wisdom!
To Whats the trick to fitting a Katech 103mm?
