-89 Lingenfelter running real bad, ECU?
Old May 17, 2026 | 04:00 PM
pierrel's Avatar
pierrel
Default -89 Lingenfelter running real bad, ECU?
I'm working a 1989 C4 with a lingenfelter engine fitted to it.
It's running really bad, smoking black on startup, and does not want to run. Have to keep the foot on the gas pedal to keep it alive.
Issue started during driving. All of a sudden it just didn't run right, and ever since I haven't found the issue.
One time it actually ran great all of a sudden, with Diagnostic tool installed and while scanning
If I have understood correct, with diag tool installed, it bypasses some functions and locks timing etc?
I've changed coolant temp sensor, MAF, spark plugs, wires, fuel pressure is OK, diaphragm OK.
No error codes while reading with diag tool nor via jumping the OBD connection.
Could it an ECU issue? Or distributor issue?
Any ideas are welcome!
Old May 17, 2026 | 07:06 PM
Tunedperformancedotorg's Avatar
Supporting Vendor
When you say pressure is okay, does it hold after a prime ?
Old May 19, 2026 | 04:41 PM
pierrel's Avatar
pierrel
Yes sir, it does hold after a prime.
Based on the amount of black smoke out the tail when cold starting, I feel it should be a fuel issue. But of course it could be a spark issue as well
And no difference when disconnecting MAF for fueling change
Old May 19, 2026 | 04:51 PM
Supporting Vendor
Might try a moates xtreme aldl cable and tunerpro rt to view sensor data. If it’s rich already no point in unplugging the maf.
__________________
Old May 20, 2026 | 05:26 PM
scorp508's Avatar
scorp508
Yes, certain ALDL modes disable knock retard.
When a memcal (the thing that holds the EPROM chip) fails the ECM can go into a limp mode, which on a modified engine is horrible. I had this happen once to my '87 and the ride home was awful.
Does it act poorly on a dead cold start, or only once warmed up? If it only happens once the scanner shows closed loop, then I'd suspect O2 sensor wiring or sensor. If it is also a problem in open loop something more fundamental is wrong.
Old May 20, 2026 | 06:03 PM
Supporting Vendor
A bit flip effects checsum and a code 41 or 51 and rapid blinking ses will occur.
Old May 21, 2026 | 12:54 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
WHICH coolant temp sensor did you change (OK...one isn't really a CTS but it senses temp for dash). O2 sensor? You wouldn't think so because open look at startup. Mine wouldn't run (all of a sudden 2-3yrs back. I did two things: O2 sensor AND cleaned the grounds on the ground block behind the batter. Maybe it's the later? TBH, I can't remember which components or sensors are grounded there. Mine got bad enough it would blip off while running too. (Like 2nd-3rd time after symptomm started.
Old May 21, 2026 | 04:17 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
If the CTS is broke, ie the one the ECM uses to determine temperature for running correctly, your car will run like crap. The sensor for the gauge, no biggie.. I think that is on the cylinder head? The CTS for the ECM? Not sure where that is, but it is the critical one
Old May 21, 2026 | 05:47 PM
pierrel's Avatar
pierrel
Did try a scanner some time ago. Will take some time and hook it up again.
Would images of said scanner during scanning give any insights?
It acts poorly straight from cold start, and will not get better when temperature rises (and entering closed loop). So its the same in both open and closed loop.
Sorry, not following on the "flip effects checsum" part?
I did change both the one on the cylinder head (before knowing it was only for cluster), and the one on the intake/under the throttle body where the coolant passage is.
I doubt O2 sensor since it does it on cold start as well. And this problem started whilst driving.
Will have a look at the ground at the battery location.
To -89 Lingenfelter running real bad, ECU?
