Hi from TX! Advice for working on a c4?
Old May 17, 2026 | 11:07 PM
CherryTX's Avatar
CherryTX
2nd Gear
Default Hi from TX! Advice for working on a c4?
Hey all! I’m Cherry and I just got a 1984 corvette that I’m working on with my boyfriend he’s more of a car guy than I am but I got this car knowing it was a project car cuz I want to learn.
It runs and drives, just got her some brand new tires. I’ve only got 3 real issues left if y’all have any advice/tips!
1. Front brakes aren’t getting any brake fluid and won’t bleed. Back brakes bleed fine, but front ones don’t even have fluid getting to the lines so I assume it’s the master cylinder unless there’s some trick I’m missing. They won’t work at all, so it’s not quite safe enough for me to want to drive around yet.
2. One of my headlights (drivers side) is not attached but I think I have all the pieces! One is in the mail on the way though.
3. A/C just doesn’t even try to turn on. Idk what that even could be but no matter what I switch or where I slide the sliders, it’s not doing anything. Help!
But thanks y’all, from what I can tell this is a super cool community I’m glad to be a part of
Old May 18, 2026 | 01:32 AM
Welcome and moving this to C4 Tech for assistance.
Old May 18, 2026 | 10:23 AM
kkupec02's Avatar
kkupec02
welcome!!
Old May 18, 2026 | 02:52 PM
Magnet's Avatar
Magnet
The CorvetteForum family is the best place for information, learning and then giving back to the CF community ! You will be able to learn alot from simply researching previous threads because almost every known issue has already surfaced here; even some with photos and how-to videos.
Welcome to the CF !
Old May 18, 2026 | 05:11 PM
bajasam's Avatar
bajasam
Do yourself a favor and pick up a set of factory service manuals first thing.
Old May 18, 2026 | 05:25 PM
CherryTX's Avatar
CherryTX
2nd Gear
thanks for the tip! I found one online
Old May 20, 2026 | 05:57 PM
Rogue One's Avatar
Rogue One
^^^ This X100.
Run some compressed air through your brake lines to see if they are clogged. Make sure your brake fluid is clear. If it isn't, flush and replace with fresh fluid (DOT 3 or 4...DOT 3 is factory fill). Your car is 42yo...I'd recommend replacing the brake hoses as preventative maintenance. Brake fluid is very caustic and will deteriorate hoses from the inside.
I know the later climate controls have diagnostics. I'm not sure if the '84s do. Check the low pressure switch for operation by unplugging and jumping the wires in the connector. If it turns on, your refrigerant is low (the switch is a lockout so you don't run the compressor while empty). Your system uses R12 from the factory which is very hard to find as it's no longer used. If you need refrigerant you have two choices: Call around to see if any shops still have R12. A few might. Otherwise you'll have to convert the system to R134a. Do NOT mix the two....this is a process.
Welcome aboard.
Old May 20, 2026 | 10:27 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
When working on the brakes, open the hood and experience the wondrous miracle of the clamshell hood.
Old May 21, 2026 | 09:39 AM
Torqsplit's Avatar
Torqsplit
You'd lose those "bonding moments" you two shared in the wheel well together ❤️ but yes, opening the hood creates a much greater space to work around 👍🏻 While you're at, grease the hood release latches and spring pins with a nice waterproof wheel bearing grease. It'll keep it working smoothly and help minimize strain on the release cables. No fun getting locked out of the engine bay! Good luck with it! Cheers on the car & Power to ya for getting in there with him and getting your hands dirty 😉 it can be greatly rewarding 👍🏻
Old May 21, 2026 | 11:42 AM
IHBD's Avatar
IHBD
Pro Mechanic
I had one front caliper that refused to bleed. No flow. The banjo fitting was clogged with crud. Remove the bolt that holds the hose to the caliper. With a little piece of stiff wire probe the hole into the hose. Push the pedal by hand slowly to purge the line. Reinstall the bolt and bleed normally.
Old May 21, 2026 | 01:24 PM
mike1111's Avatar
mike1111
yeah, open hood when working on brakes. I would remove bleeder, pump the brakes and see if fluid comes out. If no fluid comes out, bleed the master cylinder and work toward wheel and see where its plugged. If replacing master cylinder, I tried 2 auto parts store rebuilds and both leaked at reservoir seal. ended up getting Raybestos.
AC won't work if it low on freon. can jump the wires at AC clutch to see if clutch is work, would only do that for a second or 2. plenty of videos for headlights.
Old May 21, 2026 | 11:18 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Good luck with it. Looks pretty clean from what is seen in your photos. Maybe upload a picture of the engine whenever.
Here's one of those neat old MotorWeek presentations. Those things were cool back in the day. This one is about the '84 ''Plastic Fantastic'' specifically, whenever you're bored and have a half hour to kill...
To Hi from TX! Advice for working on a c4?
