Sponsored by: Wheel Design
Do you think this tire is repairable?
Old May 18, 2026 | 01:35 PM
REDEVIL's Avatar
REDEVIL
Default Do you think this tire is repairable?
Picked up a small screw this weekend. 11,700 miles in my 2023 Stingray, so there is enough tread for several thousand miles. I’d hate to throw both tires away to get two new rear tires. I will pull the wheel off this afternoon and take it to America’s Tire. Just curious on what I should expect. It looks far enough away from the shoulder but it is not directly in the middle of the center crown area. Thoughts?
Popular Reply
May 18, 2026, 10:46 PM
REDEVIL's Avatar
REDEVIL
America’s Tire patched it. Back on the road!
Old May 18, 2026 | 02:08 PM
huggerorange73's Avatar
huggerorange73
2026 Corvette of the Year Finalist - Modified
2025 C6 of the Year Winner - Modified
St. Jude Donor '12-'13
I think you will be okay....just keep in mind only one repair is allowable on these tires.
Ask me how I know lol
Old May 18, 2026 | 02:14 PM
Duck916's Avatar
Duck916
I'd fix it. But most shops will not.
Old May 18, 2026 | 02:28 PM
Kbmwgt's Avatar
Kbmwgt
Easy fix. Done many times on my C7. Of course the C7 only has 93k miles
Old May 18, 2026 | 02:40 PM
papillion's Avatar
papillion
Default Double Dandy
Not only is it fixable, Discount Tire will fix it for free.
Old May 18, 2026 | 02:55 PM
REDEVIL's Avatar
REDEVIL
I heard about that. I'd rather do the one repair now, then have to spend another $1000 on tires.
BTW, I sent you a private message about the Borla topic we have going on.....
Old May 18, 2026 | 03:08 PM
Dale06's Avatar
Dale06
I had a similar nail in the rear tire of my 16 Z06. I plugged it (very difficult) and drove about 5000 miles and traded the car.
Old May 18, 2026 | 03:09 PM
GOLD72's Avatar
GOLD72
Based on my experiences, DT will repair if 1” or more from the shoulder.
Old May 18, 2026 | 05:14 PM
89L98's Avatar
89L98
Borderline. In my opinion.
Old May 18, 2026 | 05:20 PM
jagtoes's Avatar
jagtoes
1 1/2 inch from the tread edge is NO REPAIR . I would be surprised if any tire shop will do it
Old May 18, 2026 | 05:40 PM
RKCRLR's Avatar
RKCRLR
Michelin ZP tire punctures can be repaired as long as the puncture is in the tread, doesn't exceed 1/4" diameter, the tire is removed from the rim for inspection, is repaired from the inside with a plug/patch system, and there are no other repairs. That puncture looks like it is in the tread to me.
Old May 18, 2026 | 06:24 PM
Jon2kZ's Avatar
Jon2kZ
I thought this would be too close to the edge, but America's Tire plugged this one for my Honda.
Old May 18, 2026 | 06:30 PM
Ltngdrvr's Avatar
Ltngdrvr
Well, if it were mine, and the tire stores refused, I would sure do it myself with a plug kit.
Old May 18, 2026 | 06:51 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Does it even leak air? Pull it out.
Old May 18, 2026 | 10:45 PM
REDEVIL's Avatar
REDEVIL
yes it leaked. That’s how I found out.
Old May 18, 2026 | 10:46 PM
REDEVIL's Avatar
REDEVIL
Old May 19, 2026 | 04:04 AM
walkcoal's Avatar
walkcoal
Cruising
For the safety I would change to new tire.
To Do you think this tire is repairable?
Old May 19, 2026 | 09:54 AM
hawkgfr's Avatar
hawkgfr
Yes it is.....
Old May 19, 2026 | 12:50 PM
Tranz Zam's Avatar
Tranz Zam
Excellent. There's so much nonsense online nowadays about patching tires, but the reality is virtually every puncture is patchable unless it's thru the sidewall.
Now if it's a track car, but all means replace the tire. For everything else, patching is fine.
Old May 19, 2026 | 10:03 PM
Tonylmiller's Avatar
Tonylmiller
I agree, it should be fine for highway use. However, we should remember that these tires are high speed rated. I would not take a tire up to its speed rating limit if it has been repaired.
