TPMS sensors
Thanks
JMO342
There are counterfeit sensors, but usually not in real GM packaging.
Lots of tire stores will use some other brand and claim they are just as good. Maybe.
It costs a few more bucks, but I just buy sensors from our local Chevy dealer. I don't want to be trying to diagnose sensor problems on a road trip a thousand miles from home.
Check the date-code on the sensor to make sure you are getting one with a fresh battery.
The Date code is printed on the black plastic side edge of the sensor, white ink, formated:
GM sensor:
xxyyy CCCCCCCC
13598775
Schrader replacement sensor:
xxyyy CCCCCCCC
20223/3033
the "xx" is the year ("26" = 2026)
"yyy" is the day of the year (1 to 365)
"CCCCCCCC" is the unique ID number of that sensor, that gets learned to the TPMS system
"13598775" is the GM part number on a GM labeled sensor.
"20223/3033" is the Schrader part number for the replacement sensor
https://www.rockauto.com/en/moreinfo...pt=12036&jsn=1
The shop was concerned with them activating, but it took like 2 miles and 7 minutes for them to sync up.
1. I don't install parts. I don't sell
2. I will install it but if it doesn't work, you are on your own to deal with the seller.
I was told by Costco that they can't guarantee the sensors I bought would work with my car and there's nothing they can do if they don't work. Also said I could use the ones they sell. They said the right things that covered their ***. I'd expect most shops to do the same.
