here is what I have done since then:
1) swapped the aftermarket headlight back to OEM, but installed LED bulbs with resistors
2) replaced the side markers ( had LED all white hen lit, changed to Amber/red
3) swapped console bezel ( with switch)
I have 2 switches, I tried the originsl switch again tonight, does not work, neither switch activates the Hazards
But turn signals work without issue
at night hazard button is back lit, once I press it, it is no longer lit, I assume the backlight flashes when it works. I guess it is possible I have a bad switch. What else can i look at to try and get the hazards to work?
