Sponsored by: Wheel Design
Shear plate bolts.
Old Yesterday | 10:38 AM
EvanD's Avatar
EvanD
CF Community Team
Default Shear plate bolts.
I want to swap out the stock ones for standard. 20mm or 25mm long? Zinc plated or "high-quality alloy steel class 10.9, which has higher corrosion resistance and anti-rust "? I think stainless would be overkill. What about dissimilar metal corrosion or needing anti-seize?
25 is enough to get, right? It's been 2 1/2 years since I did it last time.
Old Yesterday | 11:14 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I bought some from Amazon. I haven't installed yet.
25 of the M8 is good. I was thinking of using low-strength Loctite but it probably isn't needed due to locking flange.
M8-1.25 x 25mm Flanged Screws Flange Hex Bolts, Stainless Steel 18-8 (304), Plain Finish, DIN 6921, 25 PCS M8-1.25 x 25mm Flanged Screws Flange Hex Bolts, Stainless Steel 18-8 (304), Plain Finish, DIN 6921, 25 PCS
Old Yesterday | 11:28 AM
RKCRLR's Avatar
RKCRLR
@C5racecar showed some bolts that he purchased which looked similar to the OEM bolts but hex head.
Old Yesterday | 03:07 PM
Zymurgy's Avatar
Zymurgy
Moderator
I think you are referring to this post: https://www.corvetteforum.com/forums...post1609632066
Old Yesterday | 03:21 PM
EvanD's Avatar
EvanD
CF Community Team
I did see the post, sorry I didn't respond. I'm looking at more standard bolts without the locking cuts on the flange. Like these.
Amazon.com: (50 Pieces) M8-1.25x20 Class 8.8 Hex Flange Bolts Screws UNC Coarse Full Threads Zinc Yellow : Industrial & Scientific Amazon.com: (50 Pieces) M8-1.25x20 Class 8.8 Hex Flange Bolts Screws UNC Coarse Full Threads Zinc Yellow : Industrial & Scientific
Zinc plated is good? 20mm long is good?
Old Yesterday | 05:18 PM
Donwuan's Avatar
Donwuan
I use these kits sold at auto part stores or on Amazon.
Old Yesterday | 05:26 PM
jh61408's Avatar
jh61408
Just be warned, Stainless has a tendency to galling and not want to be removed. Especially adding Loctite too.
Old Yesterday | 05:31 PM
RKCRLR's Avatar
RKCRLR
Zinc should be OK with aluminum. 20 mm length may be a little short but I'm not sure.
Old Today | 12:24 AM
dr.k.1's Avatar
dr.k.1
Mine were 25mm long. My notes say 36 bolts total but that may include a few of the smaller bolts as well.
Old Today | 08:00 AM
EvanD's Avatar
EvanD
CF Community Team
Thanks
Old Today | 08:12 AM
V Vette's Avatar
V Vette
Thanks
Evan why not put the access door in if you remove panel now? Assuming your doing DCT changes and then won't need to swap bolts?
Old Today | 10:30 AM
EvanD's Avatar
EvanD
CF Community Team
I might do an oval opening without a door, I haven’t decided.
Old Today | 02:50 PM
V Vette's Avatar
V Vette
Awesome. May I suggest to make the oval the same width as the oil opening (they will be in line) and about 8" long. That is not only best looking but most practical. Good luck!
To Shear plate bolts.
