Replacing Headlight Motor Gear and Bushings
Old May 20, 2026 | 04:47 PM
edenrock69's Avatar
edenrock69
Default Replacing Headlight Motor Gear and Bushings
Hi Everyone, I have a 1996 C4 and in the process of replacing the gear and bushings on the passenger side headlight motor. The bushings have disintegrated hence the motor will not shut off. The problem I ran into is upon removing the motor from the headlight assembly and opening up the housing to get to the gear, I can't get the gear out of the housing. The gear is on the stem and moves freely but is stuck in the housing for some reason. I watched a video and the guy said to put a screw driver thru the hole on the stem and pull. I did but it won't pop loose. Note: On the drivers side there is an opening on the housing to get a screw driver in and push the gear/stem out using a hammer. The passenger side doesn't have this design. Any suggestions on how to remove the gear that is on the stem out of the motor housing? Thanks.
Old May 20, 2026 | 06:29 PM
Rogue One's Avatar
Rogue One
Mine was stuck also. I opened up my vice and put the gear on top (not in the jaws) and used a metal pin punch and gave it a few smack with a hammer. It popped free. Might want to spray a little WD-40 in there also.
I'd also suggest replacing with a brass gear set instead of plastic. You don't want to do this again. Good luck.
Old May 21, 2026 | 12:46 PM
BET VETTE's Avatar
BET VETTE
Metal does sound better but let’s see if anyone has used them. I did get a pair for the just in case I need it one day
Old May 21, 2026 | 07:03 PM
edenrock69's Avatar
edenrock69
Thanks for your advice. From that I did get this project done.
Old May 21, 2026 | 09:08 PM
BET VETTE's Avatar
BET VETTE
Metal or plastic
Old May 22, 2026 | 08:46 AM
edenrock69's Avatar
edenrock69
To All. From a response to my problem I was able to replace the motor gear and bushings to finish project. Thank you for your help and concerns
To Replacing Headlight Motor Gear and Bushings
