In my genius I guess last time I changed my oil on my 15 Z51 I over torqued the side drain plug and stripped the pan. Today when changing it all the threads came out with the plug, yea yea laugh at me 😭. I’m gonna retap the hole, but, my tap and die set is too long and the oil cooler core is blocking it so I can’t get it straight into the hole. Can I easily drop the core momentarily to tap the hole? Or if someone has a recommendation on a tap and die short enough to get up into the space.
I see this all the time. Way to many people think a bolt has to be tightened to extreme. 99.99% of the time an oil drain plug will not leak oil, if it's just 1 uga chuga tight.
yea idk how I even did it. I always hand tighten with a ratchet and then like 1 more quarter turn. That’s how I tightened the front drain plug and that one is fine. Just need to get the cooler core out of the way to tap the hole
If you are not familiar with using Helicoils, do some research. It will be far superior than just re- tapping the aluminum to a larger size. Essentially, you will be doing that anyway. A Helicoil kit will come with a drill bit, tap and inset tool with steel inserts that won’t strip out in the future. And you will be able to use the original size drain plug. You will be drilling it larger to install the insert. This has been an industry standard for decades. Some companies install Helicoils in aluminum parts , when they are manufactured for the exact reason of a more robust and secure thread. Some cylinder heads have Helicoils spark plug inserts. The aircraft industry uses them for many applications. If you take your time and do it correctly, it will be there forever, with no further issues.
Wonder where he went, hasn't posted since December .
huh? Wasn't this posted yesterday?
anyway, if you are trying to NOT remove the cooler you could always use a tap with a very short thread length (some are less than an inch) and cut the shank and just
grind flats back on what's left and make a super short tap.
Even if you go the heli coil route (not necessary but fine) you still have to tap it so either way you need to do that unless you can get that cooler out of there.
yea to make it easier on myself id prefer to remove the core, but im trying to find if i can just unbolt it and move it out of the way for a few minutes to drill and tap or if i have to drain the coolant too like if i was removing the entire oil cooling system
don’t blame it all on yourself. If you bought the car used, then you have no way of knowing what the previous oil changers did and how much they over tightened and stressed the threads.
