Fuel additive
Old Yesterday | 05:49 AM
ALLEN007's Avatar
ALLEN007
Default Fuel additive
Thought about adding some fuel additive to my 76. Any suggestions?
Old Yesterday | 06:50 AM
Newbomb2469's Avatar
Newbomb2469
What is your objective with the fuel additive?
Old Yesterday | 07:20 AM
ALLEN007's Avatar
ALLEN007
They advertise, better gas miliage, runs better, etc... who knows? That's why I'm checking here.
Old Yesterday | 07:22 AM
Newbomb2469
I just run non-ethanol fuel in my 75.
Old Yesterday | 07:29 AM
ALLEN007's Avatar
ALLEN007
Yes, same here.
Old Yesterday | 08:12 AM
signify's Avatar
signify
Do not add anything but gas and high test would be an advantage. The reason the additives might affect your fuel sock filter in tank.
Old Yesterday | 08:21 AM
Piersonpie's Avatar
Piersonpie
Fuel is fuel at the end of the day. As long as it’s the proper octane rating your engine needs there’s not much improvement to be made on it unless you want to get into BTU contents and nitro methane, but I don’t think that’s what you’re after.
If you’re looking into making the engine run better I would check your ignition timing and fuel curve.
Old Yesterday | 08:36 AM
ALLEN007's Avatar
ALLEN007
Thanks all for the input.
Old Yesterday | 09:31 AM
Zanny1's Avatar
Zanny1
I run regular grade ethanol fuel in my L48 1975 coupe. Recurve, per Lars recommendations, really helped in terms of performance. An occasional bottle of seafoam goes in the tank, which was a recommendation from a friend who owns several NCRS C3 cars. Q- jet Carb works perfectly, so I can't argue with success. I drive the car at least once a month and try to keep fresh fuel in the tank at all times.
Old Yesterday | 09:49 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Buy Top Tier fuels (Shell, Texaco, Mobile, Chevron, etc) and fill with regular grade, premium if you hear pinging or if going into storage. These fuels have premium additives that do indeed clean combustion chambers (esp. Chevron's Techron). I believe a non-Top Tier tank fill plus the additive price will pretty much cancel out filling with Top Tier in the first place.
For an overview of fuels and additives, look up Lake Speed Jr. on YouTube - his channel is The Motor Oil Geek. He's a long-time oil expert on formulations for both oil and gas. I know he has at least one dedicated video on fuel additives.
Old Yesterday | 10:05 AM
pltmgr's Avatar
pltmgr
Since I don't drive much and live in a high humidity climate I use Seafoam and once a year Techron cleaner.
Old Yesterday | 01:05 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The only thing that I have addd in the past is either a fuel stabilzer for long term storage, especially with lower octane gas, or Dry Gas if I suspect there is a lot of water in the fuel I have in the tank....the alcohol in the dry gas helps to break up the water and bind to it to flush out the fuel system....its mainly a winter issue up here though.
The octane boosters help but you have to use a lot of it to actually boost your octane. A standard compression motor will not need it...anything above 12:1 compression is most likely going to need somewhere north of the 93 octane available in my area....and the 100 octane pump gas was always $10 a gallon so its not in the cards to consider....my buddies 12.25 :1 motor needed the 93 and a can of booster at every fill up...
Old Yesterday | 01:18 PM
Laughing Coyote's Avatar
Laughing Coyote
Veteran: National Guard
Since I can't get non ethanol gas or find anything thing higher than 91 in Arizona I use Stabil stabilizer for when it sits for a while. The car has been having a run on issue and after resetting the timing and everything else I can do to prevent it, it still does it. The car has high compression and I think it needs higher octane gas so I have used Lucas octane booster and seems to work. The next one I'm going to try is VP racing octane booster.
Old Yesterday | 02:57 PM
Rescue Rogers
Thats the one my buddy uses...Maddtive from VP...I bought some when i built my 427 just in case, thankfully its fine with 93
Old Yesterday | 03:24 PM
Golfobsessed's Avatar
Golfobsessed
There is a Shell station up by lake pleasant that sells 110 octane... I mix it 10% with 91 octane to get me to 93... my 70 L46 likes it better than the straight 91 octane.
it was $16 a gallon last time I got it and I need to get more, looking forward to the new price
Old Yesterday | 05:04 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
a stock 76 will run just fine off 87 pump gas. just go through a tank every eight months
Old Yesterday | 10:08 PM
socal_tom's Avatar
socal_tom
I myself always buy a good grade os gas and throw in some fuel injector cleaner sometimes
To Fuel additive
