Battery Sensor Module Calibration
Background
As some/many/most may know, the Stingray with the FLA battery has a Battery Sensor Module (BSM) that is attached directly to the negative terminal of the battery. The negative battery cable connects to the BSM - so all current that flows out of the battery or into the battery flows through, and is measured by the BSM. That along with measuring "resting" voltage is how the Body Control Module (BCM) estimates the battery state of charge, which it then uses to select the system charging mode and also can use that for load shedding. There is an additional connector on the BSM which is how it communicates the info it collect to the BCM.
As a result there are two "semi important" things to be aware of (again I think many/most know this part too). And they are 1) when using a charger the negative lead of the charger cable must be connected to chassis ground and not directly to the negative battery post. Otherwise you will bypass the BSM and its estimate of the battery SOC will be skewed. If you charge via the port in the frunk, then it is properly connected, no problem. And 2) If the battery was replaced or charged out of the car or improperly charged, the Service Manual indicates that the BSM need to be "calibrated". The procedure is extremely simple - just shut the car off and leave it undisturbed for at least 4 hours.
What Happens the Calibration get Out of Whack?
With that as background - here's why am writing about this. I really wondered if this calibration step is essential. As far as I know, when someone installs a new battery, themselves or even at the dealer, it does not seem as if anyone observes the calibration as urgent. I just had a new battery put in my car at a dealer, and I drove it around - it did not sit for 4 hours until much later. So.....is there really any consequence to delaying the calibration step? I don't think so - not very much. But I did stumble across some info about it in the Service Manual that indicates some situations where it might be a (minor) issue (to make a short story long). Just thought I would share it. You can tell its a "generic" GM description, because it mentions Start-Stop, and although Erays have that feature, this description has been in the manual since 2020. But what I found interesting and potentially relevant to us is that improper charging might cause the BSM to indicate a default SOC of 65% and prevent an OTA.
And, I have found nothing about if or how the charging system adapts to the battery type. I do know its possible, though I have no reason to think that the C8 does all that. The new CTEK flagship charger does not need to be told anything about the battery , but will charge FLA, AGM, and Li batteries.
https://www.ctek.com/us/battery-char...one-(gen-2)-na
