1990 C4 Base Model A/C not working
Old May 21, 2026 | 08:57 PM
altownsend's Avatar
altownsend
Default 1990 C4 Base Model A/C not working
1990 C4 Base Model A/C not working. All of a sudden, my A/C stopped working. From cold to A/C clutch not turning. I took the negative battery cable off to reset the A/C. Nope, did not work. I put my gage on, and the needle showing charge went to mid red.
So, what should I try next? I changed out the o=rings about 2 years ago, and everything was wonderful for all of this time. What additional testing should I do to get to a fix? Thanks
Old May 21, 2026 | 11:36 PM
arbee's Avatar
arbee
Well, I guess finding the leak would be next. Put some UV dye in and charge up enough that the compressor kicks in (doesn't need to be fully charged - wasted gas.)
Old May 22, 2026 | 12:04 AM
altownsend's Avatar
altownsend
Yes, Arbee,
That was the first thing I did. The system did not take any freon. I put the dye in, then tried to get the compressor to activate by adding freon. I did not get a response from the compressor, so I took #2 fuse out to reset the system, still , no response from the compressor. I then removed the negative cable from the battery and let stand for about 15 minutes, then reconnected the cable to the battery. No response from the compressor.
While reading about this in the Service Manual, the Service Manual connected the power connector to the radio to this issue. Last week, I removed my Pioneer stereo to send it back for service.
Question: Might the removal of my stereo trigger this issue? The Service Manual comments about removing the power connector, I think disabling the A/C system. Is this true, or am I reading too much into the comment about the radio power connector?
Old May 22, 2026 | 05:57 AM
mazdaverx7's Avatar
mazdaverx7
If the system deterct too high of a pressure, the high pressure switch will stop the compressor from cycling to prevent damage. You may also want to apply source voltage to the compressor connector with the engine off to see if the a.c. clutch engages and disengages when voltage is taken away. If the clutch does not engage, it has failed.
Old May 22, 2026 | 08:31 AM
arbee's Avatar
arbee
Unless the switch itself is faulty, the high pressure cutoff does not enter the picture here. The switch opens ~450 PSI and is impossible to reach that point sitting static. The OP states the compressor is NOT activating. I will repeat in this thread - the wiring diagram is in the FSM. Get out a meter and find out where the power stops. Problem solved!
Old May 22, 2026 | 01:47 PM
BET VETTE's Avatar
BET VETTE
When mine stop working I did a on dash reading and code 9 came up……low Freon
Old May 22, 2026 | 03:55 PM
mrlmd's Avatar
mrlmd
Where and how are you measuring the pressure in your AC system? You can not measure pressure in your AC system without the compressor running - you are measuring a static pressure which is useless. You probably have low pressure in the system and it is now working as designed, shutting off the compressor to prevent damage to it. If your compressor is not running, you cannot add Freon into the system, and you have to bypass the low pressure switch to get it to turn on, then you can add Freon.
Did you pull the code, is a blinking green light showing up on your AC control panel?
Do a search on here on how to bypass the low pressure switch (and where it is). You also have to reset the 09 code if you have it by disconnecting the battery for 15-30 sec or so before the compressor will turn on.
Old May 22, 2026 | 11:02 PM
arbee's Avatar
arbee
You are mostly correct but for one thing. The low pressure switch does not shut off the compressor to protect against damage. It shuts off to stop the evaporator from becoming ice bound. Once the pressure drops below~28 PSI, the temperature goes below 32°. So long as the compressor has oil, it doesn't care if it is pumping anything. No different than an engine. If you had a starter that would not burn up, you could crank it till the cows come home and so long as it built oil pressure, no problem.
Old Yesterday | 08:04 PM
mrlmd's Avatar
mrlmd
You are also mostly right. The compressor will shut off to prevent the evaporator from icing up but will also shut off because of insufficient or low oil lubrication due to low coolant (Freon) levels.
This from the net as well as AI - Low pressure just above shutoff will cause compressor overheating and shutdown on thermal cutout or seizing from insufficient oil return - no lubrication.
So without getting into an argument, both answers are right, for two different reasons.
And as an aside, if the Freon level happens to be OK, the other reason his compressor doesn't run could be a rare failed low pressure switch, easy to test for.
Old Today | 12:27 AM
arbee's Avatar
arbee
OK. One certainly wouldn't want to question AI.
Old Today | 02:42 PM
mrlmd's Avatar
mrlmd
It's as valid a statement as yours. "So long as the compressor has oil" - where does that oil come from? If the system pressure is too low, there is insufficient coolant (Freon) and its contained oil circulating, so the compressor can heat up and be damaged, both from low oil as well as the cooling property of the liquid flowing through it. The low pressure switch turns off the compressor to avoid it being damaged as well as the evaporator freezing up. Do you disagree with that? Personally I would think it is more important to save the compressor from damage than to prevent some ice forming on the evaporator.
To the OP - if the system would not take any Freon, how did you put dye in? You need the compressor to run to put anything into the system unless you have the proper high pressure AC equipment to do that.
Unless you try to bypass the low pressure switch by removing the electrical connector and shorting out the switch with a short piece of wire to get the compressor to turn on, you will never add anything to the system and you are wasting your time with other measures which will not help you at all.
Do a little more research on here,
or do yourself a favor and take it to an AC repair shop.
To 1990 C4 Base Model A/C not working
