C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
10% off EVERYTHING we make at AMT Motorsport starts NOW
Old May 22, 2026 | 07:03 AM
Mark@AMT Motorsport's Avatar
Mark@AMT Motorsport
Supporting Vendor
Default 10% off EVERYTHING we make at AMT Motorsport starts NOW
It's that time again folks! Starting RIGHT NOW and running thru Memorial Day, every AMT product on our site is available at 10% off when you use coupon code "CF26" at checkout. This is your chance to save some serious coin on big ticket items like our Spherical Bearing Kit, The Wing of Power, Finger of God, X-Wife Drop Spindles, and will also yield substantial savings on Camber Kits, Spacers, Motor Mounts, Diff Mounts, Seat Mounts - oh my!
Head to www.AMTMotorsport.com to take advantage of the discounted pricing.
We've listed some of our products below in case you may be unfamiliar with what we do.
C8 Aero - The Wing of Power, Finger of God, Zebulon Splitter, Quick Release Splitter Hardware
The only trunk/frame mounted, reverse swan neck, all US-made, CFD and Wind Tunnel-tested, carbon fiber track wing available for the C8 - or any car. Pair it with a Zebulon front splitter and our quick release system, and you have a streetable track car with a 1.94:1 L/D ratio. There is no more powerful aero package available for the C8 Corvette. By a factor of 2. Period.
There's a lot to unpack, so click here to learn about all of our C8 Aerodynamic offerings
C5-C8 Monoball Control Arm Bushings
If you're looking for slot-car like handling for your Corvette then a set of monoballs is probably the best money you can spend on your car. The car is transformed and so much easier to drive on the limit. We use the best materials available and custom fit each part to your YOUR control arms. All you have to do it send them to us and we take care of the rest, and return shipping is included.
Follow this link if you would like to turn your car into a race car.
C5-C8 Ultralow Seat Mount
This is the lowest, strongest, safest billet seat mount available for the Corvette. It will put your seat on the floor if needed. Using this mount with the Sparco QRT-R seat I gained almost 2 inches of head room over MTI rails with a Sparco EVO. Our integrated sub belt takes the guess work out of installing your 5 or 6 point harness. Not only that but it will survive an 85G mostly-rear impact. This seat mount saved my life and it can save yours too - just hope you never need to find out!
Follow this link to get yourself low.
C7/C8 Titan Tow Hooks
Made from 7075-aluminum and hardened 17-4PH stainless steel, this US-made aerospace-grade tow hook could actually tow a space shuttle. So it'll look bitchin' on your street car or pull you out of a tire wall easy peasy.
Prepare for launch here
C5-C8 Adjustable Camber Kit
The product the launched our company is available for all C5-C8 Corvettes. If your car sees any serious track time than a camber kit is virtually required equipment. Set your alignment once and never worry about it again. Everything is USA made and guaranteed for life.
For more info on C5 and C6 camber kits follow this link. For the C6Z/ZR1 head over here. To solve problems for all C7s head this way.My C8 peeps should take a look seeright here
Differential Mounts - C5 and C6
Mitigate wheel hop and stop your trans from flopping around during hard cornering with our offerings for the C5 and C6 Corvettes. Rather than knocking off the same product that everyone else has for the last 15 years, we came up with fresh and updated designs to address short comings from competitors. These billet pieces firm everything up without a huge increase in NVH and they are guaranteed for life.
For the C5 check this out and for the C6 check that out.
X-Wife Drop Spindles for C5 and C6
Combine GSpeed design with AMT Motorsport manufacturing and what do you get? The best God-damned drop spindle on the planet that's what! Machined on our 5 Axis CNC, they start out as 70 lbs blocks and wind up as the 6.5 lbs beauties you see before you. Available in plain finish or your choice of anodized colors.
Learn more about the X-Wife by clicking here.
C4-C7 Wheel Spacers
We offer 4 different sizes of wheel spacers. Our 1/4" spacer uses the lip of the stock hub for centering and can be used with stock length studs. Our 3/8" spacer pushes the wheel out a smidge further but the ring on the hub is no longer effective. We recommend going to the 2.5" ARP studs if you're using a 3/8" spacer. We also offer 3/4" and 1" spacers with a machined lip for centering. These spacers should use the 3.25" ARP studs.
For 1/4" and 3/8" spacer head this way. For 3/4" and 1" go that way.
C5/C6 Vulcan Motor Mounts
These mounts are now on their third variation and better than ever. A single bolt keeps your motor from moving fore and aft, while vulcanized rubber dampens the vibrations so they're not as harsh as solid mounts. We now use a hard anodized 6061 center section to keep the 2 rubber pucks in each assembly where they belong. Make no mistake these mounts do not feel like the pillowy soft oil-filled gushiness of the stock mounts. You are definitely going to feel more of the engine with these mounts, but your 350 lbs lump of a motor will not be moving all over your engine bay either when performance driving.
Follow this link to order yourself up a set of motor mounts
C5-C6 Extended Gas Pedal
Our product makes heal/toeing your C5 and C6 Corvette a breeze. It's a cheap and effective mod to increasing your driving enjoyment and I guarantee you'll love it or I'll give you your money back.
To make your Corvette easier to drive at the limit,
click here.
C7 M80 Adjustable Toe Links
After selling a different product for a number of years, we've decided to start making our own version of adjustable toe links for all C7 Corvettes. The previous product had fitment issues with various parts and quality issues with the heim joints. Trying to work with the supplier to correct the issues wasn't getting anywhere, so in order to best serve our customer base, we came up with the AMT Motorsport M-80 Toe Links which use 7075 aluminum, 17-4 PH pins, and FK Heim Joints for the strongest and longest lasting toe links on the market.
Head here to snag a pair.
Thanks as always for the support!
Old May 23, 2026 | 11:49 AM
Mark@AMT Motorsport
Supporting Vendor
__________________
Mark Petronis, 2023 C8 #266
President - AMT Motorsport
Mark@AMTMotorsport.com
Facebook The 'Gram
518-877-8560
Old May 25, 2026 | 09:49 AM
Mark@AMT Motorsport
Supporting Vendor
Your last chance to save 10% on everything we make - ends tonight! Just use discount code "CF26" at checkout.
And speaking of “10”, we just realized that our customers have been making Porsches have an inferiority complex on track for the last 10 years! It’s incredible to me that 10 years ago this company started because I didn’t want to buy Chinese-made performance parts, and your support throughout the years has shown that I wasn’t alone in that line of thinking. So thank you for 10 years of support. Support of American ingenuity, design, testing, and manufacturing. Happy Memorial Day to you all! - Mark
To 10% off EVERYTHING we make at AMT Motorsport starts NOW
