C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
2026 Z06 Iron brakes to Carbon brakes question...
Old May 22, 2026 | 10:36 AM
ChrisKo's Avatar
ChrisKo
Default 2026 Z06 Iron brakes to Carbon brakes question...
Is it possible to put OEM carbon ceramic rotors and pads on a 2026 Z06 with iron brakes and use the original calipers?
Thanks.​​​​​​
Old May 22, 2026 | 11:55 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
The part numbers are different for the calipers for w/CCB and w/out CCB. I could be wrong, but I believe the actual caliper spec is different as the CCBs are designed to operate at a much higher temp. I know originally on the C6 ZR1, even the hubs were different to handle the higher heat. I believe there also might be a difference in the MagRide calibration due to the unsprung weight difference between CCB and iron-rotor brakes.
Old May 23, 2026 | 10:44 PM
X25's Avatar
X25
Sr.Random input generator
The caliper size is different. You need the CCB calipers. They're usually cheap, though, especially if you can find them on RockAuto, etc.
Old May 24, 2026 | 08:21 AM
Bossman2024's Avatar
Bossman2024
Thanks.​​​​​​
No as others have said the calipers are different as the rotors are a different thickness. A much cheaper alternative is to get the conversion kit from Competition Carbon which uses the stock calipers for iron disks, but replaces the rotors and pads. The rotors are the more modern gen 3 materials that come with the ZR1 brakes (or if you get stock CCB calipers redone with Rebrake). So will wear better anyway.
https://www.competitioncarbon.com/pr...ent-conversion
Old May 25, 2026 | 12:31 AM
Vette_17's Avatar
Vette_17
I wish it was simpler to replace. There is zero brake dust on my ZR1. The only regret I have is getting the iron rotors on my Z06.
Old May 25, 2026 | 02:58 AM
ahalachis's Avatar
ahalachis
I pretty much have zero dust with my iron brakes after switching the pads to Carbotech 1512s….$600 fix
Old May 25, 2026 | 10:25 AM
PhoenixM3's Avatar
PhoenixM3
How’s the stopping power? Diminished over stock? I went with Powerstop low dust pads and like the low dust, but think there’s a loss in performance.
Old May 25, 2026 | 10:39 AM
Bossman2024
I had the Carbotech pads and the stopping power was awesome. But they will fade so for hitting the canyons or something you would want to swap back to a better pad. But for regular street driving they were great.
To 2026 Z06 Iron brakes to Carbon brakes question...
