[C2] Cluster and tach cable
Old Today | 04:09 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Cluster and tach cable
My '66 with A/C. If I lower the steering column and pull the instrument cluster out a few inches, will I have enough room to unscrew the tach cable?
The only other possibility is removing the A/C duct under the dash and try to unscrew it from the bottom.
What have others done to change the tach cable without removing the steering column and completely removing the cluster?
Old Today | 05:25 PM
anyChevy's Avatar
anyChevy
Originally Posted by Captain Bud
The only other possibility is removing the A/C duct under the dash and try to unscrew it from the bottom.?
That worked for me last week
Old Today | 06:18 PM
Tampa Jerry's Avatar
Tampa Jerry
Pick up four 1/4 by 20 X 3" carriage bolts. replace the mounting screws with the bolts and slide the cluster back. That should give you enough room to change out the cable. Keep an eye on the oil pressure line. Good luck. Jerry
Old Today | 08:30 PM
BAmacker's Avatar
BAmacker
You don't need to loosen the cluster. This has been covered several times in the last few weeks, do a search.
Old Today | 08:35 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Just take the AC duct out reach up and unscrew it and take the cable out, it’s tight. No need to take the instrument cluster out and you would have to take the air duct out anyway to drop the steering column.
To Cluster and tach cable
