CTEK lithium ion battery charger safely and effectively charges and maintains LiFePO4 batteries up to 120Ah, extending their lifespan. Check it out on Amazon now!
https://a.co/d/0324dMSF
I've got 8 of these! Simply the best! Pig tail directly to the battery.
That's going to be an awfully long power lead, going from the very back of the car to the front, under the bonnet.
Ya know those "jump-start" posts? I'd connect a short power lead to those, then plug/unplug from there. It's already under the bonnet, so "cracking" the bonnet open shouldn't trigger a lamp illumination.
Those jump-start posts will feed the battery using the existing wires.
The battery in a C6 ZO6 or a 427 vert is in the back of the car, my CTEK came with a pigtail that connects directly to the battery & a quick disconnect about a foot away from the battery, I leave the trunk lid slightly ajar & just leave the power wire & charging unit lay on the garage floor. When I take the car out, I simply disconnect the quick connect in the trunk & drive it away
