Points and coil.
Old Yesterday | 07:07 AM
Plasticexperience's Avatar
Plasticexperience
Default Points and coil.
Hi all, looking for some advice on to where to buy a set of points and a coil for a 63 corvette fuelie. Looking for the best quality.
Thoughts??
Old Yesterday | 08:01 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I have been running auto parts store points for 15 years 10k miles with no problems. I run an original coil.
Old Yesterday | 11:05 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
A lot of very knowledgeable engine tuners here recommend the Echlin brand points & condenser from NAPA. (Echlin is made by Standard Motor Products.) There are a bunch of eBay sellers offering the NOS AC Delco points at pretty reasonable prices. Do not go with the Unipoint design where the points and condenser are one unit.
I have an NGK coil in my '67. I trust their spark plugs, so figure their coil must be good too.
Old Yesterday | 12:34 PM
Nowhere Man
I am going on a limb here and say there is only one manufacture for all these parts. just different boxes and labels.
true story I bought a set of NOS points years ago opened the foil package they looked brand new no sign of water damage. and my car would not run no matter what I did. put the old set of auto parts store points back in and it fired right up. do good luck buying old tune up parts
Old Yesterday | 01:13 PM
Scott Marzahl's Avatar
Scott Marzahl
https://www.corvetteforum.com/forums...ty-points.html
Old Yesterday | 02:46 PM
acstephenson's Avatar
acstephenson
I recently had a very similar experience with a set of 70+ year of Delco-Remy NOS points. They looked perfect with no sign of damage or oxidation or protective coatings on the contacts but absolutely would not fire despite everything being perfect before the replacement. In my case, a single pass of a burnishing blade completely cured them and the engine has been fine since. I suppose decades of in-the-box oxidation will do that.
Old Yesterday | 03:10 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
This is a known problem today with new in the box points sets. They sit in that box for a while, given the call for them and oxidize as everything does. Guys install them and the car will not run. All you need to do is run a dollar bill through the contacts once or twice and the car starts. Happened to me.
Dan
Old Yesterday | 05:07 PM
R66's Avatar
R66
Here in IL, NAPA sells "Blue Streak" points made by Standard Motor Products SMP. Accel used to make some heavy duty points (stronger spring) which were good for high RPM, but I don't know if they are still available.
SMP sells different grades of parts to compete with the Furrin' stuff. I try to use their best even though a bit higher $$$.
To Points and coil.
