FS: (SOLD) 1982 Corvette GM crate motor, 700R4
Car is located in Quakertown, PA.
$11000.00
Curious how these C3's handle with more power, do the long gears keep the rear end from breaking loose?
What work needs to be done?
In fact, the 385 hp rating of the engine is complemented by excellent low-rpm torque, with the SP350/385 generating 405 lb.-ft. of torque at 3,600 rpm. It’s all due to the high-flow, lightweight aluminum cylinder heads. They’re based on the proven Fast Burn design, with large intake runners and 2.00/1.55-inch valves. The beehive valve springs enable greater high-rpm performance and durability, allowing the engine to rev higher to make the most of every cubic foot of air drawn through it.
As with all of Chevrolet Performance’s Small-Block crate engines, the SP350/385 is built with a cast-iron block with four-bolt mains. It also features a forged steel crankshaft, an aggressive hydraulic roller camshaft and durable, highsilicon pistons. In this value-driven Base crate engine package, it also includes the intake manifold, distributor, water pump, damper and flexplate. Other accessories are required to finish it – all available from Chevrolet Performance.
TECH SPECS
Part Number: 19333157
Engine Type: Chevy Small-Block V-8
Displacement (cu in): 350
Bore x Stroke (in): 4.000 x 3.480
Block (P/N 10243870): Cast-iron with 4-bolt main caps
Crankshaft (P/N 12670965): Forged steel (shot peened)
Connecting Rods (P/N 10108688): Powdered metal
Pistons (P/N 10159436): Hypereutectic aluminum
Camshaft Type (P/N 10185071): Hydraulic roller
Camshaft Lift (in): .474 intake / .510 exhaust
Camshaft Duration (@.050 in): 208° intake / 221° exhaust
Cylinder Heads (P/N 19300955): Fast Burn aluminum; 62cc chambers
Valve Size (in): 2.000 intake / 1.550 exhaust
Compression Ratio: 9.6:1 nominal
Rocker Arms (P/N 10089648): Stamped steel
Rocker Arm Ratio: 1.5:1
Recommended Fuel: Premium pump
Ignition Timing: 36º Total @ 4,000 rpm
Maximum Recommended rpm: 5,800
Balanced: External
Flexplate (P/N 14088765): 12.750"
Intake Manifold (P/N 12366573): Dual Plane
This is the only mods listed above for engine, new aluminum radiator, 700R4 transmission. Electric headlights.
No frame damage or bird cage issues, I’ll try to get some photos this week.
Never tried to break tires loose, I’m just a cruiser, not drag racing.
Nothing needs to be done at present.
