Fuel Pump Insulator - What the heck does it do?
I thought it might be of interest to some because we see, or used to see, reports of the a sewing machine tic-tic sound which is usually attributed to the high pressure fuel pump and/or the fuel injectors. This component may have a role in reducing the noise that is heard. It appears in both the Coupe and Convertible. The part number is 12698115. Surprisingly there are several for sale on ebay too.
Below are some images, one showing the underside with appears to be molded to cover the fuel lines. It does not completely cover the fuel rails.
Quote Google AI
"High-pressure direct injection (DI) fuel pump normally makes a distinct ticking, clicking, or rattling noise. Because it operates at incredibly high pressures to atomize fuel directly into the cylinders, this clatter is completely normal for direct-injection engines."
"The high-pressure fuel pump (HPFP) in a C8 Corvette operates up to 3,600+ PSI (roughly 100 to 250 Bar). This mechanical, camshaft-driven pump is required to step up the low-pressure feed (46–84 PSI) from the in-tank electric fuel pumps to meet the extreme demands of the direct-injection (DI) system."
