Better Sounding Exhaust --On The Cheap
Old May 24, 2026 | 07:30 PM
AMichiganHoosier's Avatar
AMichiganHoosier
3rd Gear
Default Better Sounding Exhaust --On The Cheap
I just bought a very low milage '07 LS2. I can barely hear it running.
Is there a low cost way to get more sound out of the exhaust ---without buying a lot of new plumbing????
My budget is broke for the for seeable future
Mark
Old May 24, 2026 | 07:43 PM
JKNAPP's Avatar
JKNAPP
delete the cats
Old May 24, 2026 | 07:49 PM
AMichiganHoosier
3rd Gear
What's the best way to do that????? Can a "shop" just make that happen??? and what do you think it would cost?????
Is that illegal?????
Thanks Mark
Old May 24, 2026 | 10:36 PM
K03's Avatar
K03
You could go through all of the trouble to delete your cats, or you could just do a muffler mod. There are plenty of how to threads here for the muffler mod. And it won't give you a check engine light.
Old May 25, 2026 | 06:05 AM
sirdano's Avatar
sirdano
Do you have NPP mufflers? Look at mufflers and see if it has a valve on top. If yes you can remove the fuse and it will be open all the time
Old May 25, 2026 | 06:53 AM
99Hawk262's Avatar
99Hawk262
Cut the mufflers off and have a shop fill in the gap/weld on some tips. You’ll hear it then
Old May 25, 2026 | 08:17 AM
Spaceme1117's Avatar
Spaceme1117
Mark
If your car came with the NPP muffler option, just need to pull the fuse for them to have more sound.
If you car didn't come the NPP option, cheapest way to get more sound is to buy a set of used NPP mufflers and replace yours. If you want more sound all the time and don't need the valves to work, that's all you need.
To Better Sounding Exhaust --On The Cheap
