C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
2nd oil change last week, now at 58%
Old May 25, 2026 | 09:29 AM
bshaw's Avatar
bshaw
Default 2nd oil change last week, now at 58%
I reach the annual calendar countdown for oil change on my 24 Z06 before the mileage countdown.
Took it to my dealer last week for the second oil change and now the app is saying 58% oil life remaining.
Why wouldn’t I start at 100% oil life and have it go down by ~8% per month until 12-months has passed again?
Old May 25, 2026 | 09:31 AM
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
Did the dealer reset the OLM? If yes, OLM can glitch. Just reset it since it was done last week. If not, same solution, just reset it.
Old May 25, 2026 | 09:51 AM
bshaw's Avatar
bshaw
The car and app were reporting 0% before the dealer visit, so they must have reset it. Maybe I’ll keep any eye on it and report back if 58% changes significantly. I will likely reach 12-months again before mileage limit, so I don’t need the OLM to be precise.
Old May 25, 2026 | 09:52 AM
Asleep@thewheel's Avatar
Asleep@thewheel
I did my first oil change a few months ago, and reset the OLM to 100%. Did a quick test drive to insure no leaks.
The next day I replaced the brake pads with low dust pads. As part of that procedure I disconnected the battery.
When I reconnected the battery the OLM had dropped to <50%. I just reset it again with no further issues. It can get glitched up.
Old May 25, 2026 | 10:19 AM
X25's Avatar
X25
Sr.Random input generator
It's probably fixating on the mileage target. Since you're not putting a lot of miles, it'd probably go down pretty slowly from there on. I frequently change my transmission fluid due to track use, and it drops back targeting that 7500 or 22500 mile maintenance the next day..
Old May 26, 2026 | 01:18 AM
JohnDS's Avatar
JohnDS
I don't get it. It's a car, not a computer that runs your life. Change the oil when it needs to be changed.
Old May 26, 2026 | 08:34 AM
Zjoe6's Avatar
Zjoe6
Sounds like a bug. No way you should lose 42% in a week without driving it 3000 miles (is that even possible?).
Old May 26, 2026 | 11:15 AM
lgodom's Avatar
lgodom
The OLM isn't flawless. I had mine freeze in the 50% range for 3 months last year. Took it the the dealer and there was no resolution from GM tech. Decided to use my first free oil change and it's worked as expected since then.
To 2nd oil change last week, now at 58%
