'67 L36 Oil Leaks and recommendations on Gaskets, Seals
For the first 25 years of C2 L36 ownership, I had the good fortune of a 427 that didn't leak oil. The last eleven years I've been continuously chasing engine oil leaks with no real success.
Any thoughts on using the following gaskets and seals: 1. Oil pan gasket: Fel-Pro Performance #1884R 2. Rear main seal: Fel-Pro Performance #2904 (2-piece silicone) or #2918 (2-piece Viton)? 3. Timing chain cover: Fel-Pro #TCS 45060 4. Intake manifold gasket set: Fel-Pro #1275 S-3 5. Valve cover gaskets: Fel-Pro Performance #1635
Recommendations on better alternatives are appreciated as well.
I may be an outlier but I have been using the Fel Pro Silicon Rubber gaskets with rigid center like the 1884 and 1635 with good success. I know a lot of guys still like the cork but they just keep deforming and collapsing to where after a few years they just seem to weep all the time. I think I used a gasket similar to what you proposed for the intake.
