Sponsored by: Wheel Design
How to start in sport mode
Old Today | 01:35 PM
08redrocket's Avatar
08redrocket
Default How to start in sport mode
How do I start the car in the Sport mode.
Now, I start the car and it is in Cruise mode.
Old Today | 01:40 PM
RKCRLR's Avatar
RKCRLR
Restarting in Sport mode isn't an officially supported C8 Stingray feature. Some early C8s would restart in Sport mode (my 2020 does) but it isn't supposed to according to the owners manual.
You need to use My Mode to have it restart in My Mode. All other modes default to Tour on restart.
Old Today | 01:57 PM
Andybump's Avatar
Andybump
If it doesn't, then you can't.
If you shut off in MyMode it will start up in MyMode. Otherwise, it generally will default to Tour mode through an ignition cycle, and if you are in Z-mode and exit Z-mode using the Z button, it iwll default to Tour. There have been reported instances where the car will retain Sport Mode through a ignition cycle, but there is no menu setting to "enable" that. It's just a software difference. Which is why I say, if your's does not retain Sport Mode through an ignition cycle, then you can't change that.
Old Today | 02:18 PM
Revmanii's Avatar
Revmanii
Huh. I have '22 pre-production. It's starts in sport mode.
Old Today | 02:22 PM
EvanD's Avatar
EvanD
CF Community Team
What is a preproduction?
Old Today | 03:01 PM
Andybump's Avatar
Andybump
That's right...its different on come cars. But there is no setting to change the way it defaults, right? It either does or it does not retain Sport mode through an ignition cycle.
Old Today | 03:13 PM
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
That's interesting. My 21 has always maintained whichever mode I had it in when shut off...thought that was the normal behavior.
Old Today | 03:19 PM
Andybump's Avatar
Andybump
I've never heard anyone say it will retain Track Mode through an ignition cycle. Are you sure about that? My 2021 works in accordance with this statement from the 2021 manual:
"If the vehicle is in Tour or My Mode it will
stay in that mode through future ignition
cycles. If the vehicle is in any other mode, it
will return to Tour when the vehicle is
restarted."
As I noted, some have found (even in 2021 I think) that it will also retain Sport Mode through and ignition cycle. Mine does not.
But regardless, OPs question was is there a way to get it to retain Sport Mode through an ignition cycle. The answer to that is no. It either does it or does not, but there is no setting to change the way it defaults.
To How to start in sport mode
