wom't pull past 4k rpm!! ??
Old Yesterday | 07:33 PM
tebrules's Avatar
tebrules
Default wom't pull past 4k rpm!! ??
my 2012 GS has about 55k miles and suddenly doesn't pull past 4k. It will still gain rpms, but not really pulling hard and you can tell something is wrong.
No error codes at all. Pulled the three abs fuses to see if it was the active handling but it was the same result. Tried searching the forum.
thanks in advance guys. Tom
Old Yesterday | 08:09 PM
csnow's Avatar
csnow
My guess would be fuel starvation, clocked cat, TPS, or possibly cam or crank sensor unless you have been bouncing it off the rev limiter recently.
Old Yesterday | 08:39 PM
tebrules's Avatar
tebrules
would any of these throw a code? It seems like everything throws a code!!
Old Yesterday | 08:45 PM
tebrules's Avatar
tebrules
Old Yesterday | 09:10 PM
csnow's Avatar
csnow
Just to makes sure, you aren't testing this in park/neutral are you? There is a rev limit set to prevent damage. That could also be a culprit, that switch could have failed and the ECU thinks it's in neutral. The others should throw a code but a bad cat might not but it would have to building a lot of back pressure to cause what you are seeing.
Old Yesterday | 09:18 PM
hubes's Avatar
hubes
Something simple to check that probably isn't the problem, but is your air filter so dirty that it's no longer blue?
Old Yesterday | 09:19 PM
DrKrieger's Avatar
DrKrieger
When was the last time you cleaned your throttle body and MAF sensor? Us the proper cleaners, on the MAF sensor use the specific MAF sensor spray cleaner. Try this firt and see what happens.
Old Yesterday | 09:53 PM
tebrules's Avatar
tebrules
does it all the time(manual trans) air cleaner is good. will try cleaning the MAF. ty
Old Today | 12:00 AM
Qshiplover's Avatar
Qshiplover
I know you said you didn't get any codes showing up, but just as a fluke you may want to check the fuel pump fuse to see if it is getting sketchy making intermittant contact. I did a post a while ago after getting stranded.
https://www.corvetteforum.com/forums...-fuse-box.html
To wom't pull past 4k rpm!! ??
