Can a C5 handle the snow?
I would rather put funds towards creating an INDOMITABLE C5 that can power through anything I feel like putting it through rather than buying a POS winter beater. (Should I buy a winter beater? Probably. Will I? Probably not.)
My initial plan of attack is to convert my suspension from stock to coilovers so that I can adjust ride height without completely swapping my suspension at the turn of the seasons every year.
Question is, will that be enough? How much play will I have? 2in higher than stock ride height? More? Less? Does it depend on the coilovers? Are there better, more adjustable suspension solutions that can be used in all 4 seasons?
I will be buying a second set of rims with winter tires on as well. Is there anything more that I can't think of that would improve the car's ability to tackle the elements?
Can I feasibly make something that will be adjustable between seasons? Will I be able to adjust the coilovers down to a low ride height in the summer and then back up to something capable of clearing those wheel well ice chunks in the winter?
The question here isn't "Should I?".
It's "Can I?" And more specifically How?
If anyone has any experience with projects like this one or if anyone has some quality recommendations I'm all ears.
If you just want to gripe that I'm ruining the car because I want to drive my favorite car all year round, you can drop those comments here as well, I'm sure they'll be fun to read
Thank you in advance!
But for a set of tires, wheels and coil overs it will cost as much as a beater.
‘Also resisting the car up is going to make it wonky to drive as a Corvette is not made yo drive that high up unless you rework things.
Even then the front intake will still be a scoop in the snow.
I drove my Fiero 3 years in winter when I was young. I had no choice till I got my truck. I generally could drive daily in the winter with no mods. If the snow got deep I borrowed my mom’s car for a day. Roads are generally plowed.
let’s face it 80% of the time you can drive it on winter tires no mods. Just do that and keep a junker just for the 20% of the time when it is storming.
As long you are ok with winter body damage that is up to you.
I just would not get crazy lifting a car on coil overs as it is too much cost and work to do and undo and will not drive as you like how it drives. Too much compromise here.
(this advice is being offered by someone with over 50 years of experience in winter driving)
Note: my Corvette was my daily for the first year I had it. Even then, I didn't drive it in snow or ice. (We don't usually get a lot in VA). When it did snow, I'd get a ride from my wife. After that first year, I bought a beater truck specifically for when the weather was bad.
What I'm getting here is winter tires are the most dominant solution, whereas coilovers to adjust the ride height is not advised.
To all of those that think the road salt is going to be an issue, I bought this car second hand and the previous owner did enough damage to the paint where this is not a concern until I choose to repaint my vehicle. Additionally, I undercoat every car I own to extend the longevity of the vehicles I drive where I live. Finally, I have grown up driving through the worst of winters and have over a decade of experience, as well as the defensive driving mind of a motorcyclist since I spent years on two wheels as well.
I still believe additional ground clearance will help to avoid ice chunks and to minimize time the air dam is being used to shovel snow. However there are some lift options I can pursue without swapping completely to coilovers.
Rest assured that I am not a proud owner of a unique and pristine C5, my poor old man has seen his share of poor TLC until I got him.
This year I'll stick to a second set of rims with my snow tires on them. If I decide I need to do more, I might document my experiments here.
Thanks again for the comments. I appreciate y'all taking your time to pitch in.
I can't find any Impreza that cheap. Additionally, a completely separate vehicle with all of its own maintenance and insurance costs sounds much more expensive no matter what I get.
