no oil pressure shutoff?
Old Yesterday | 09:47 AM
Red86Cfour's Avatar
Red86Cfour
Default no oil pressure shutoff?
Does the 2014 C7 ECU have shutdown ability if it sees zero oil pressure? I suppose one could disconnect the oil pressure sender while the engine is running, but I don't have that option right now.
Anyone who has dealt with ECU tuning know the answer?
Also, is there a separate oil cooler in the front below the radiator? This is a 2014 Z51 M7
Thanks!
Old Yesterday | 10:11 AM
rtv900's Avatar
rtv900
I don't think anything shuts down at zero pressure.
Think of the danger if you were on the highway or something and the ecu just shuts down the engine?
Z51 is dry sump right?
If so I'm pretty sure the cooler is right next to the secondary drain plug. That stacked brick type thing.
Old Yesterday | 11:47 AM
Red86Cfour's Avatar
Red86Cfour
I'm looking for information from tuners that have modified the ecu settings and know whats in it.
I'm not debating whether its a good idea or not. For more of the story, my car was stolen and got to participate in a side show. The police showed up before they could torch it, which is apparently sop for events like this. It appears that they hit something up front, maybe a curb or something low, because there are streaks of what look like coolant (but could be oil) coming from below the radiator air inlet. It apparently overheated (I'm assuming) and actually blew the coolant reservoir cap off and the escaping steam blew off the under hood insulation pad. There are also drips of what look like oil under the radiator, and more importantly, the dry sump tank is empty. When I got the car back, not knowing the tank was empty, I tried to start it, which it didn't. It just cranked over, very easily. So I'm just trying to piece together what might have happened, so knowing that it has no oil pressure I'm wondering if thats why it won't start. Hell, it could be outta gas, I haven't checked that as the car is stored at the bodyshop.
Old Yesterday | 11:51 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
IIRC, our 2001 owner manual said that the engine would shut down if oil pressure got below 5 (?) psi. Don't recall seeing that on our later C6/C7, but that doesn't mean much. GM Owner Manuals are written by the summer intern on his last day there.
Old Yesterday | 12:08 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Thanks!
No !!!...and disconnecting the sensor won't do anything as far as shutting the car down.
Old Yesterday | 12:40 PM
rtv900's Avatar
rtv900
ugh that sucks
maybe even worse that they didn't torch it and now you have that nightmare to deal with
did you get no insurance money out of it and just a trashed car handed back?
Old Yesterday | 03:08 PM
Red86Cfour's Avatar
Red86Cfour
ugh that sucks
I have an unofficial (long story) estimate from the insurance company. Its almost all body and paint, plus two new rear wheels and tires, engine covers and reservoir cap plus underhood insulation. With only that estimate I don't believe they'll total it. But, I don't believe they realized the radiator is most likely cracked, that it most likely was overheated, and is empty of oil. The engine turns over freely it just doesn't start. I've looked around inside the engine compartment and I see no evidence of oil anywhere. So the only thing I can figure is that somehow the radiator and oil cooler were damaged and thats how it lost oil. I won't even consider accepting it back until the pan gets removed for an internal inspection, and the transmission and diff fluids are drained.
The insurance process hasn't gone the full distance yet, so I'm still waiting to hear what their verdict is, or what I want to do to go forward.
Old Yesterday | 03:11 PM
Red86Cfour's Avatar
Red86Cfour
Thats the kind of info I'm looking for. So its probably a sure thing that it ran with no oil for who knows how long. Since it still turns over, its just a matter of determining why it won't start, even with the high probability of trashed bearings. It should still run I'd think.
Old Yesterday | 03:19 PM
rtv900's Avatar
rtv900
yeah it could easily run with major damage, short term
but you don't see any damage that could have lost all the oil right? Like no smashed pan or cut oil lines?
where did the oil go?
If it's in your possession and you think there's major legit internal damage maybe get the thing running (with no oil) and let it seize up and just say that's how you got it back
Old Yesterday | 05:44 PM
Red86Cfour's Avatar
Red86Cfour
Its at the bodyshop. Originally, it was at the tow yard where I first saw it. I never opened the hood, I just tried to start it just to see if it was still alive. At the time it was my understanding that it would go to a special inspection facility run by the insurer and that would be my last goodbye. That turned out not to be the case, and instead it went to the bodyshop of my choice. When I went to visit it a second time at that shop, thats when I noticed some oil spots underneath the radiator area and that it had no oil. So its my assumption that the radiator was cracked, and any oil cooler (or line) was compromised, and thats how it ran out of oil.
Old Yesterday | 07:59 PM
Red86Cfour's Avatar
Red86Cfour
Ok thanks for your replies everyone. Insurance is calling it a total so now the search can start.....
Old Today | 10:20 AM
laserdude2215's Avatar
laserdude2215
I didn't read everything, but you should know that, after sitting for just a few hours, the dry sump tank will appear to be empty.
Old Today | 01:21 PM
Red86Cfour's Avatar
Red86Cfour
I did wonder about that, and thanks for that suggestion. I actually never checked it to see where the level was after several hours of shutdown. I always followed the manuals guidelines for checking it five minutes after shutdown. Its possible the engine may be ok but still too many unknowns to want it fixed, and insurance didn't even give me that option. I have a buddy that can do body and paint himself, so I've requested a buyback price and maybe he will get it, and maybe even get lucky that the motor isn't fried. But for whatever reason, it won't start. It may be out of gas, I just never checked for that possibility. Didn't pull codes or even see if a check engine light was on.
Old Today | 01:50 PM
rtv900's Avatar
rtv900
so I've requested a buyback price and maybe he will get it, and maybe even get lucky that the motor isn't fried. .
buying the salvage is a good idea if you just want to keep the car for yourself until you bite the dust.
otherwise it can be tricky because the value of the car will essentially be zero since it will have a salvage title.
And you can only insure it for liability for that reason too, so if you wrecked it you'd be out of a car, or worse yet if somebody nails you and is
100% at fault you will still get nothing paid to you because the value will be more or less zero when the persons insurance company finds out it's a salvage.
Old Today | 05:20 PM
Red86Cfour's Avatar
Red86Cfour
Wrong. I've bought and owned salvage before. I had no problem insuring it, or selling it later on. If fixed and running and registered, even as a salvage title, it doesn't have zero value. Maybe to you it does, but to others thats not the case. Salvage titles allow people to get into a nice car that they might not otherwise be able to. I don't have the desire to fix it or do the work to part it out, but somebody who does their own body work and paint, and isn't afraid to change an engine if need be, could build a very nice car for themself. When youre filling it up at the gas station and it looks awesome, nobody asks if its a salvage, and you don't have to tell them. If done correctly, it will corner and accelerate just as well as one without a salvage title. I don't see a problem here.
To no oil pressure shutoff?
