Voltage difference
Old May 26, 2026 | 10:50 AM
Sailfish5's Avatar
Sailfish5
2nd Gear
Default Voltage difference
Voltage problem. At rest my 03 C5 driver info center reads 11.8 volts. At the battery it reads 12.5 volts Does this cause a battery OVER charge?
Old May 26, 2026 | 11:09 AM
abc63's Avatar
abc63
No, it will not cause an over charge but it does indicate an under charge. It also indicates (with the tools you are using) a 7 tenths of a volt, voltage drop from the battery to the BCM.
Old May 26, 2026 | 11:30 AM
sonata2.0T's Avatar
sonata2.0T
The car's volt meter reads about a half a volt less the actual voltage, nothing to worry about.
Old May 26, 2026 | 11:32 AM
lucky131969's Avatar
lucky131969
I believe you meant "IPC"....not BCM.
Old May 26, 2026 | 12:16 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As you can see a here a 0.41 volt difference between DIC and battery charging voltage.
Old May 26, 2026 | 12:38 PM
Fast one's Avatar
Fast one
The lower voltage shown on the dash gage compared to a measured voltage on the battery terminals is caused by the extra resistance of the wiring and ignition switch contacts, it's unlikely the dash gage will ever give the true exact voltage value of the battery. The alternator regulator circuit doesn't reference the dash gage for charging control, it's independent from that.
Old May 26, 2026 | 08:25 PM
Sailfish5's Avatar
Sailfish5
2nd Gear
Thanks for the info. New to the Corvette. Just installed an Optima red top and that 11.8V from the d.i.c. was a little unsettling.
To Voltage difference
