Strengthening rear suspension
Old May 26, 2026 | 03:08 PM
_Orphan_Crusher_'s Avatar
_Orphan_Crusher_
Default Strengthening rear suspension
I intend to put a 383 (about 425-450 hp and 430-460 ft/lbs of torque) and a different transmission and some more sturdy rear diff gears in my ‘75 c3 sometime in the future. I’ve seen people saying that the rear suspension won’t be able to handle the power if I put anything other than street tires on it (I will just be running street tires on it). Is the rear suspension actually that weak, and is there one specific part that I can replace without too much hassle or it getting too expensive? I know people would recommenced replacing the entire rear end but im quite inexperienced in suspension and would not like to fully disassemble the rear end. I also like the independent rear suspension just because it handles better.
Old May 26, 2026 | 03:42 PM
Piersonpie's Avatar
Piersonpie
The suspension can handle that amount of power just fine, although there’s still upgrades to be made. What you really want to be concerned about is the drivetrain. Driveshaft, differential, U-joints, half shafts, and axles.
I would get into contact with Gary Ramadei @GTR1999 and tell him the plan for your car. Even if you don’t use any of his services he’s a wealth of information on making sure the drivetrains of these cars can handle the large amounts of power people want to put to them.
Old May 26, 2026 | 05:24 PM
69L88's Avatar
69L88
With the power figures you are seeking, the is no concern regarding the suspension but you will want to seriously consider rebuilding/upgrading the differential.
Old May 26, 2026 | 08:51 PM
_Orphan_Crusher_
Upgrading the diff is just replacing the gears right?
Old May 26, 2026 | 09:21 PM
Piersonpie's Avatar
Piersonpie
You will have the answer to that question and more by doing what’s recommended in post #2.
Old May 26, 2026 | 10:09 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
ahhh, Wrong.
Old May 26, 2026 | 10:58 PM
MelWff's Avatar
MelWff
No, clutches and plates, probably side yokes, bearings, etc. Can't tell until the differential is disassembled and components checked. Also intended use of car plays a factor.
Old May 26, 2026 | 11:29 PM
69L88's Avatar
69L88
Short answer-no.
The C3 “iron” differentials (65-79) (the 63 and 64 are similar but have some differences that should be avoided and the 80-82 are aluminum) are generally good for around 450 HP/lb-ft of torque if properly built using best practices but will never be as robust as a 12 bolt. They use 10 bolt gears which are smaller.
Differentials are just one link in the chain that can blow up if you whomp on the car. Outer axles are known to twist, u-joints can fail, driveshafts can twist.
Tom’s Differentials used to offer a variety of upgrades but Tom’s is no more. Gary Ramadei (gtr1999) bought up his inventory and is the only person I know that can offer the best available upgrades but good parts, particularly gear sets, are becoming increasingly difficult to source.
To Strengthening rear suspension
