Weeping thermo gasket...
Old Yesterday | 11:27 AM
CecilVette's Avatar
CecilVette
Cruising
Default Weeping thermo gasket...
After a few fire ups I noted the thermo gasket weeping while sitting. Fluid weeping is blue in color. Thermo gasket was blue so it must be weeping threw the gasket. Got bolts tighted close to point of stripping and they are not bottoming out. Any suggestions on how to seal this?
Old Yesterday | 12:09 PM
jthornton's Avatar
jthornton
Check the flatness of both mating parts. Check for old gasket material or other junk. Over torquing never solves anything.
I only use an O-Ring seal type of thermostat housing.
JT
Old Yesterday | 01:08 PM
sunflower 1972's Avatar
sunflower 1972
Phone your neighborhood GM Dealer. Part number 10105135.
Old Yesterday | 07:45 PM
Rebelyell's Avatar
Rebelyell
discard any Asian-plated water neck. Most are warped.
US-made are available in replacement grade like Murray-Four Seasons.
Ensure both surfaces are flat & parallel.
Use a simple fiber gasket.
Don't use RTV. Instead, Thin-skim both sides of gasket with Permatex # 2 Non-Hardening. Don't look back.
*do yourself & motor a favor: R&R Hose Clamps with "BREEZE" brand in their "Breeze-LINER" series.
Old Yesterday | 10:44 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Are you sure the thermostat is against the intake with the gasket sitting on top?
How did you determine the bolts are not too long? Looks like a gap between the bolt's head and the washer here.
To Weeping thermo gasket...
