Sponsored by: Wheel Design
Stinger Stripe ?
Old Today | 01:31 PM
Bandit 2010's Avatar
Bandit 2010
Default Stinger Stripe ?
Is the factory stripe clear coated over the stripe ? can it be removed with out damage to paint ? Thank Your
Old Today | 01:51 PM
Zymurgy's Avatar
Zymurgy
Moderator
The factory stripes are automotive paint/clear coat on a vinyl substrate. There is nothing applied to them after they are installed. Yes, they can be removed without damage to the underlying paint.
Old Today | 02:59 PM
ahalachis's Avatar
ahalachis
This is correct, they are put on at the factory after the cur is build but before it ships. easily removed if needed...
Old Today | 03:13 PM
Zymurgy's Avatar
Zymurgy
Moderator
The full length stripes and stinger stripes are applied by a third party after the car is built and before it ships. Fender hash stripes and Jake hood graphic and some other graphic packages are LPO options - they are dealer installed. Online Order Guide clearly indicates which are LPO options and which are not.
To Stinger Stripe ?
