Ground your alternators ! Esp if they have a painted case
the digital volt gage was erratic. 13.2v one second and 14.6v the next. Strangely the analog voltmeter gage stayed steady…
slight whine thru the radio.
ive had the stock alternator rear brace removed to fit tall valve covers…
not an issue on corvette #1 and its unpainted alternator which must get a solid
ground thru the engine/frame.
but adding a welding cable to the frame on the back of corvette 2’s alternator case (the 3/8-16 threaded hole) fixed all these problems.
I suppose they are trying to reduce corrosion with these replacement parts but many of them are case grounded and it creates a problem.
Did you have the rear brace removed on both Vettes or just the one with the bad ground? Did your test light light up on the alternator housing before you ran the new wire?
That said, I'm a big fan of doing the "big 3" wore upgrades. It's big in car audio circles and it's useful on most cars. OEMs spec the bare minimum wire size they can, adding an extra 8, 4, or 1/0 cable to the big 3 connections helps a lot IME.
