So Don't Use Battery Tender??
I use my maintainers on cars that go a long time without being used, my generator, boat, ATV, etc.
One thing about cheap maintainers, many of them will overcharge a battery over time. Always check your battery after a few weeks being on a maintainer with a voltmeter. The voltage should be between 13.2-13.6 volts for a flooded lead acid battery. Overcharging is worse than undercharging, I prefer closer to the 13.2v end. Some maintainers will cycle instead of maintaining a constant float voltage and will go under and over this range but should still be between 13.2-13.6v on average.
Most battery maintainer manufacturers say to regularly check your electrolyte level when using a maintainer on a flooded lead acid battery. That is nearly impossible on today's sealed batteries and, at least, impactable. Continuously charging will eventually lower the electrolyte level.
If you drive the car regularly a few times a week, the maintainer is not necessary, but it is what I do. If you go more than a week, GM recommends the use of the maintainer. A battery that is disconnected but not on a maintainer will still lose charge over time. Your car charging system does not charge a battery to 100% usually. It typically will charge the battery to 80% (this is not made up - it is described in the Service Manual). So, if you have not been using a maintainer (a maintainer brings it up to 100%), and you simply remove the battery from the car for storage, then your battery starts out at 80% and looses charger from there. I personally would not do that. The battery could decay to lower, and still be able to start your car - but that does not mean it was good for the battery. I personally would still put it on maintainer even if disconnected for storage.
Looking at Pic below with info from my 2014 C7 4 volume Service Manual. Also considering @Andybump measurement of a very low parasitic current draw in his C8 of 10 milliamps NO need for even a 3 week car sit! With the C7 recall someone had his car at the airport for longer than planned, 5 weeks, and it started fine!
So if battery is 3/4 years or newer should be zero issue starting after a 3 week sit. Frankly with my E-Ray Li-Ion battery 6+ weeks. Since I drive my cars at least 2 to 3 days each week and most drives are ~60 miles round trip to town they are Fully charged. In fact my frequent observation of battery dash voltage (really alternator) in ~30 miles with Lead Acid battery after sitting for ~5 days it's fully changed. On my E-Ray less than 10 miles fully charges any loss in 5 days.
Your Car Your Choice. Always plugging it into a charger will increase lead acid battery life somewhat. If the effort and time to do that does not bother you, may be worth it for some BUT not needed.
Looking @Andybump measurement of ONLY 10 mA parasitic current draw in his C8 should be able to go 4+ weeks with C8 Lead Acid battery. Your car your choice. It's not like my 1st Vette, a 1988, with no current reducing circuits when parked!
Absolutely no issues, and whereas I used to have to replace the C3/C5 batteries every 5 years, the 7 year old factory battery on the C7 is still strong & starts the car well.
- To unplug the until from the A/C before you disconnect from the car. My CTEK owners manual recommends this and I have seen posts of not following this procedure in rare cases has caused problems.
- Don't bypass the battery charge monitor (if you use the frunk cig plug, this is a non-issue). If you use direct battery connection, connect the black lead to a vehicle ground, NOT to the negative battery terminal.
Although old, both Mercedes need some power to keep their computers happy.
The other two vehicles are ancient without computers, I plug them in to maintain their battery.
I bought the GM unit with my C8 because of TBE different power plug...or I could have bout an attachment for my current unit, but theorem was cheap enough.
No brainer.
Starting the car for ~10 minutes to left the battery charge is not a good idea! The worse thing for engine and oil is cold starts. The cold pistons let the main product of combustion, in addition to heat and pressure, WATER get past the cold piston to cylinder wall gap go into the oil. Also cold combustion chambers don't support a good air/fuel mixture so it's usually running rich for a short while. Now unburned fuel as well as water gets into the oil. If the car does not run enough the oil will not get hot enough long enough to evaporate much of the water. The water will combine with "stuff" in the Oil (and fuel) like Sulfur and forms Sulfuric Acid. It corrodes metal while the car is parked. That is why GM before the OLM (like my 1993 Vette) recommended if most drives where under 4 miles or mostly bumper to bumper driving to change oil every 3 MONTHS or 3000 miles, whichever occurs first.
BTW, is what Jiffy Lub, some dealers etc used to justify a sticker on the inside of your windshield after and oil change that said "Come back for the next oil change in 3 months or they added 3000 miles to the Odometer reading." That is based on SAE tests that showed oil gets contaminated and needs to be replaced. The OLM even under good driving conditions says change oil at minimum every 12 months. Your Owner's Manual also notes under some conditions the OLM will shorted that 12 month period.
Your car you'll do what you want but far far better to use a battery maintainer.
Although I don't use one for my DD Vettes as been retired since 2000 BUT drive several days a week and usually a ~60 mile round trip to town. I have observed over several years that my 2020 C8, if it sat for 5 days will not be fully charged until I'm in town, ~30 miles. That's driving with average rpm well past idle.
FWIW I have a street rod with an 8,2 Liter Big Block. It only goes to a few car shows each year. I keep in on a maintenance charger 24/7. Currently using the one I bought for my 2014 C7 as needed a new one for my E-Ray for the Li-Ion battery. No harm as all CTEK and most maintenance chargers are NOT supplying any current to the battery after it reaches full change. BTW I also will not pull the Street Rod out and back if I need access to a ladder! I have a ~25 mile route I take so the oil gets hot enough long enough to evaporate that cold start water that passes the pistons.
Although I don't use a maintenance charger on my DD Corvettes because not needed my Street RoD is one one 24/7!
YOUR CAR YOUR CHOICE!
PS: To Validate the above this is what Google AI said:
Yes, starting a cold engine and making short drives traps unburned fuel and water of combustion inside the crankcase. If the oil never reaches full operating temperature, the water mixes with the byproducts of fuel combustion to form corrosive acids.
Just my .02....
