Sponsored by: Wheel Design
P06DD at 150 miles, 2026 Stingray
Old May 29, 2026 | 04:11 PM
BSZ's Avatar
BSZ
Default P06DD at 150 miles, 2026 Stingray
Wife took this as I was driving home from coffee today, just picked the car up 3 days ago. :\
Per the OnStar report:
Here are the results of your recent On-Demand Diagnostic request on your 2026 Chevrolet Corvette.
Module Diagnostic Code Diagnostic Information Recommended Action
ABS - StabiliTrak® Stability Control System None No Error Code Found None
ABS - Antilock Braking System None No Error Code Found None
VIU - OnStar System None No Error Code Found None
SDM - Air Bag System None No Error Code Found None
ECM - Engine and Transmission System P06DD Service within 7 days
TCM - Engine and Transmission System None No Error Code Found None
I didn't have any long drives planned this weekend but still, at 150 miles having to drop the car off already is no bueno. Anyone had this pop up so soon? I found a bunch of other threads on it and it seems like it can go either way.
Old May 29, 2026 | 04:21 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Appears your oil level is an issue. If it's super low I wouldn't drive it to get a reading at the needed operating temperature.
Old May 29, 2026 | 05:09 PM
BSZ's Avatar
BSZ
Oil level on the dipstick looks good, and I don't see anything in the car that can tell me the level, just oil life which is at 98%. I have to assume this was checked when the car was prepped for delivery, but one never knows. Hoping it's just a sensor and not a boondoggle.
Old May 29, 2026 | 05:36 PM
Avanti's Avatar
Avanti
Such OnStar reports are notoriously wonky. Get a cheapo code-reader and see what it says. If necessary take it back to the Dealer; their problem one way or the other.
Old May 30, 2026 | 11:41 AM
Good luck with the fix - hope it turns out to be something simple.
Old May 30, 2026 | 12:17 PM
thebishman's Avatar
thebishman
Check the 12V battery voltage, especially if the car has been parked for some time.
Old May 30, 2026 | 07:00 PM
BSZ's Avatar
BSZ
Thanks! Me too, haha.
It's off to MacMulkin on Monday AM so I'm sure they'll put it right. I plan to ask them to do an oil change on it right now anyway, regardless. The level is bang on between the high and low markers when the car is cold. I have a feeling nobody actually went through the car before they sent it out for delivery.
Old May 31, 2026 | 11:39 AM
madrob2020's Avatar
madrob2020
Haven’t I read here temp needs to be at operating temperature & engine running? Why would you change oil at 98% & so few miles . Your car do as you want, just inquiring minds want to know 👍
Old May 31, 2026 | 11:47 AM
BSZ's Avatar
BSZ
The error I'm getting is oil pressure related. I did check it at temp per the manual as well - I was just adding that I checked it cold as well for context.
I don't think the vehicle was prepped correctly, so rather than drive around with mystery oil as it's throwing oil pressure related codes, I'm going to ask them to change it properly so I know it's done correctly.
Old May 31, 2026 | 12:50 PM
RKCRLR's Avatar
RKCRLR
The car comes from the factory with oil, the car is driven around a little before it is delivered. All the dealer may need to do during PDI is adjust the level if it is off. If it has "mystery" oil in it it was done at the factory. There is likely something wrong with the pressure sensing system or engine; or perhaps software related.
Old May 31, 2026 | 02:13 PM
Andybump's Avatar
Andybump
I suspect your issue is with the oil pressure control system (possibly a sensor as you suggested) - specifically for P06DD its reading over pressure. That is not likely due to the oil and certainly not a result of oil level. If this were my car it would be going to the dealer tout suite. And I most definitely would not be changing that oil until the dealer has performed the indicated diagnostics. This is a warranty issue. You can read for yourself what it is all about. It also indicates that your engine power is limited because of this condition:
Old Jun 1, 2026 | 05:48 PM
BSZ's Avatar
BSZ
Whelp, engine out it is.
They reset the code and took it for a spin to test the oil pressure. I went to pick the car back up and they said it may have been an anomaly, a bubble in the oil, or something else that triggered it. Oil levels are all good and the full diagnostic they did on it earlier in the day came back clean.
I made it about half a mile out of the dealership (MacMulkin) after picking it back up and the CEL came back on. They're going to have to drop the cradle and my best ETA for getting it back is at least a couple of weeks.
Not much the dealer can do otherwise and **** happens - just absolutely ******' sucks. i'm going to look into extended warrantees and such now, because this would have been a monstrous out of pocket bill and the car only has 200 miles on it. Not the best start to things.
Old Yesterday | 10:47 AM
Andybump's Avatar
Andybump
What are they replacing then? Ar they they removing the engine or just dropping the cradle. There are removable components, such as the oil pan, that can replaced without removing the engine, but do require dropping the cradle.
Old Yesterday | 10:52 AM
BSZ's Avatar
BSZ
This is my first C8 (or GM of any kind) so pardon the terminology if I get it wrong. As I understand it via Google:
  • Cradle Drop (Powertrain Removal): The standard factory procedure. The engine, Dual Clutch Transmission (DCT), rear suspension, and exhaust are unbolted from the chassis and lowered as a single complete assembly onto a lift table. This is used for major transmission repairs, heavy frame damage, or separating the engine and transmission blocks.
  • Engine Out (Engine Only): This entails separating the engine from the transmission while the vehicle is raised. The engine alone is then dropped from the bottom. This is more common for internal engine rebuilds (e.g., swapping a blown engine for a new block) where the DCT does not need to be serviced
I was told they are dropping the cradle, which to me means the engine and the transmission are coming out. I don't know exactly what they are replacing, and since they told me yesterday to come get the car because it was an anomaly (only to tell me an hour later that the car needs to be there for a few weeks), I don't think they have ID'd it either. I will follow up with the work reports in case someone else finds this thread w/this problem later on.
Old Yesterday | 11:15 AM
EvanD's Avatar
EvanD
CF Community Team
Unfortunatly we all have different interpretations of certain terms. Dropping the cradle could be the whole engine/ DCT assembly or just the shear plate so they can look for leaks, loose electronic connections, etc.
Old Yesterday | 11:27 AM
planojoe's Avatar
planojoe
OP, start the LL clock.
Old Yesterday | 11:32 AM
RKCRLR's Avatar
RKCRLR
Google AI is incorrect once again.
While the powertrain can be removed as a unit it doesn't need to be. The DCT can be removed while leaving the engine in the car with the proper engine support.
The cradle can also be removed while leaving the powertrain in the car with the proper support. However I don't think the engine can be removed without removing the DCT.
To P06DD at 150 miles, 2026 Stingray
Old Yesterday | 12:15 PM
BSZ's Avatar
BSZ
I'm in MA and the dealer is in NH, not sure the LL applies.
It's MacMulkin though and they've all been pretty supportive so far.
Old Yesterday | 12:16 PM
BSZ's Avatar
BSZ
Thanks. It's a several week repair so I'm assuming that's not just dropping the oil pan. I'll post a follow up once service has an actual indicator of the failure.
RKCRLR's Avatar
RKCRLR
MA and NH both have lemon laws, one would apply. And there is also a federal lemon law.
