C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Best mode for Tail of the Dragon and Blue Ridge
Old May 30, 2026 | 03:44 PM
B/Stock's Avatar
B/Stock
Default Best mode for Tail of the Dragon and Blue Ridge
Going up to do the Tail and surrounding roads. I've been there a few times but with my Lingenfelter C5 which put down around 500 and was a manual.
Any suggestions on what mode to use? Also are you manually shifting or just letting the computer do the work? Thanks
Old May 30, 2026 | 04:26 PM
pastexpirationdate's Avatar
pastexpirationdate
Track mode is always the correct answer.
Let the trans make all the decisions. If you’re able to drive it spiritedly on the day you go, you’ll be busy with other things that actually require human input.
Old May 30, 2026 | 06:54 PM
CGGS's Avatar
CGGS
Track mode is NOT always the answer. It depends on the road. On a smooth road, I agree with you, on an imperfect or rough road I disagree. Here is why...
For some reason GM tuned the MRC different in the Track setting.
You would think as you go up in settings, the dampers would get firmer and more damped on both compression and rebound. However that is not the case. That theory works going from Tour to Sport damper setting, HOWEVER for some reason on the track damper setting GM tightened the compression, but loosened the rebound damping. You can feel it as you go over bumps/dips in the road or even going over a speed bump it is noticeable.
Old May 30, 2026 | 07:02 PM
PhoenixM3's Avatar
PhoenixM3
Go track mode, with PTM sport and shift manually.
Old May 30, 2026 | 07:15 PM
NWA_Viper's Avatar
NWA_Viper
I was just there a month ago. Hit the Tail during the week and you’ll actually get to have fun.
Z mode with auto shift and send it!
Old May 30, 2026 | 07:41 PM
B/Stock's Avatar
B/Stock
Thanks for all of the input. I guess I'll try different modes and see whats comfortable. I think I'm going to miss the old school manual
Old Jun 1, 2026 | 04:25 PM
Phimosis's Avatar
Phimosis
Looser rebound to prevent "suspension packing". Answer by Google Gemini:
Loosening (or speeding up) your rebound damping is the direct fix for shock "packing".
Understanding Shock Packing
Packing occurs when your suspension compresses to absorb a bump (e.g., a rock or a whoop) but doesn’t have enough time to extend back to its starting position before the next bump hits.
If your rebound is set too "slow" (stiff), the oil is choked, and the shock gets trapped further down in its travel with every consecutive hit. This makes the ride progressively harsher, lower, and causes the suspension to top out or feel dead.
How to Fix It
  1. Reduce Rebound Damping: Turn your rebound adjuster (usually a **** or screw at the bottom of the fork or shock) counter-clockwise ("looser" or "faster") by 1 to 2 clicks at a time.
  2. Test: Ride a section of trail or road with rapid, consecutive bumps.
  3. The Goal: The suspension should return quickly enough to track the terrain, but not so fast that it feels like an uncontrollable pogo stick.
Note: Be careful not to make the rebound too loose, as the shock will start "kicking" or bucking you on bigger hits. Always make small, incremental changes and record your base settings.
Old Jun 1, 2026 | 04:36 PM
Phimosis's Avatar
Phimosis
I use My Mode. I want the exhaust full loud, but I don't want the suspension full stiff. And I want the circular tach, not the bar tach that race mode has.
And I always use manual shifting. It's just way more fun and sounds cooler when the engine is always in the powerband. If you're in sport mode and autoshifting, when you come up behind a slow moving car and are off the throttle, it will shift up and drop the rpm's down to the 2,000's. I like to keep the rpm up to 3,500-4,000 because it sounds musical and aggressive and lets the slow moving car know that you want by.
There's only 2 times when I use auto shifting: 1) at the track or drag strip going for the best possible elapsed time. 2) when I want to maximize fuel mileage, such as a freeway trip or I'm low on fuel and looking for a gas station.
Old Jun 1, 2026 | 06:19 PM
CGGS's Avatar
CGGS
How to Fix It
I understand this concept as I had MCS 2-way dampers on my previous GT4 and did all the fine tuning on both compression and rebound over about a 6 month time frame, trying about 30 different combinations. Packing only happens when your compression and rebound settings get too far apart from each other and out of the window of tuning. If you tighten up compression, you can tighten up rebound by the same amount and be good, just with a stiffer/less compliant ride.
GM follows this going from Tour to Sport, both compression and rebound stiffen and become more damped, but going to Track, they further increased compression, but relaxed the rebound. What I was expecting and what most people expect is the rebound to also further be stiffened. In track mode (at least to me) rebound can feel just a tad under damped when you are dealing with dips in the road. If you are on a smooth surface, it's no issue because you have the added support of more compression, but if you throw in dips or undulations, the rebound side feels just a bit sloppy.
Old Jun 1, 2026 | 10:39 PM
m3incorp's Avatar
m3incorp
Don't forget, there are often police running radar on the Tail also.
Old Today | 03:20 PM
B/Stock's Avatar
B/Stock
Just got back from running the mountain roads in NC and TN. For me, definitely track mode manually shifting. The car is much more responsive and fun to drive. I did use sport mode in traffic, but track mode does transform the car.
Old Today | 08:57 PM
superramvette2's Avatar
superramvette2
Manual shifting and m mode or z mode/track mode. To be honest you won’t be able to really go too wild anyway unless you get super lucky so it doesn’t matter a ton. As you know the roads are tree covered so stay damp for a long time so the back end is gonna come out on you if you are really pushing it.
To Best mode for Tail of the Dragon and Blue Ridge
