Dipstick handle pointed out
So I drain out the Shell Rotella 15W40 w/ a can of zinc additive and put back only 5 qts racing VR1 10W30 oil. The dipstick now shows the oil level at the U of Full with the dipstick pointed toward the fender. This answers the question if I have the correct dipstick and which way it should be pointed. At this point if the dipstick is pointed in, the level is just getting onto the dipstick about 1/4", showing it to be about 1 1/2 qts low. As far as the oil draining back down through the engine right at startup. The 10W30 drains down quicker which one would expect. It's just that I've never had an engine take as long to drain back down as this 327 takes, especially with the 40 weight oil. I was concerned but my uncle assured me that with the 5 qt oil pan I was in no danger. The level on the dipstick would show 1 1/2 qts low if I just ran it for a minute and then shut it off, weighted a bit and then check it.
Anyway, I searched this board and didn't find anything that really popped out about the dipstick orientation so I thought that I'd post this. My engine is a 1963 327ci 340HP which is in my 1962 vette.
I expected OP to say that with the handle pointed out, the loop hit on some part or other, preventing it from going all the way down. If that's not the case, we're dealing with muffler bearings and winter vs summer air in the tires.
Larry
Re dipstick what you are talking about is not that unusual - if the lower tube is missing the dipstick is entering the pan on an angle and you get the readings that you see - not a big deal.
You just need to calibrate / train your brain to accept whatever the level is showing cold after a full oil change (when you know there are 6 quarts in there)
During my rebuild I took the empty pan and filled it with water--quart by quart and making a careful count. I noted the exact level of oil in the pan with each quart. The pan was advertised as a 4 qt pan and at 4 quarts the pan was full enough that when I went for a 5th quart, it was immediately obvious that the level was MUCH too high. Then I took an old spin on filter and carefully measured that---at one quart--I COULD have added a touch more but not enough to really matter and also because it was an OLD filter, there probably was a bit of oil absorbed in the element so at 1 qt I decided enough was enough.
After re-assembly, I prefilled the filter with 1 qt, filled the pan qt by qt and took careful note of the level on the stick---both ring in and ring out, with each qt. The drew a diagram in my engine log that showed qt by qt---both ring inward and ring outward. The results were consistent---Ring inward was always noticeably LOWEWR than Ring Outward.
At the 4th qt I simply said "4 its for the pan and one for the filter-----then LEAVE IT ALONE!"
Started the engine for a minute then shut it down.
A half hour later, the Dip Stick ring outward showed to the FULL mark, Ring toward the block 1/2 qt lower.
I have no explanation for the difference in reading but I DO know that once I put in 5 its, the engine is full. That's enough for me.
Best,
Eddie '62
One other thing to note here----I recomend that anyone who has their oil pan removed for some reason do this---- when I had the engine on the engine stand-with the pan OFF I inserted the dip stick and it is amazing to see just WHERE that stick ends up among ALL those moving parts. It's pretty scary, actually. When you see "what's what, it sort of explains the difference in readings between ring in and ring out.
Also, if you try this with different length sticks, it is revealing as to WHY you want the CORRECT stick for YOUR engine.
Eddie
