Blueprint engines oil pan and problems with steering cylinder.
Old Jun 2, 2026 | 03:08 AM
stingraymax's Avatar
stingraymax
Default Blueprint engines oil pan and problems with steering cylinder.
Hi, I came across a post but can't find it anymore about Blueprint engines oil pans hitting the c3 steering cylinder. Anybody that has installed a BP engine and came across this problem (I have a '75 with Power steering) ? I would like to know before installing my BP engine if I need to change to another oil pan.
Thanks
Old Jun 2, 2026 | 05:00 AM
jthornton's Avatar
jthornton
I just put a Blueprint BP350CT in my 82 with no issues with the oil pan touching anything. @Fly skids up! has the same engine in his 82.
JT
Old Jun 2, 2026 | 05:53 AM
Fly skids up!'s Avatar
Fly skids up!
Yep, no issues.
Old Jun 2, 2026 | 06:14 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Put a blue print 383 in a 76 Vette. Pan hit the steering cylinder. Bent the pan slightly. Ugly. But it worked.
Old Jun 2, 2026 | 08:48 AM
stingraymax
Did you use the stock motor mounts or solid mounts ?
Old Jun 2, 2026 | 10:16 AM
jthornton's Avatar
jthornton
I wonder if the 383 has a deeper pan to accommodate the 400 crank?
JT
Old Today | 06:28 AM
USAF_Big_Sarge's Avatar
USAF_Big_Sarge
7th Gear
I put a BP 400sb in my 1976 Vette, no clearance issues.
To Blueprint engines oil pan and problems with steering cylinder.
