Railroadman
close
- Member SinceAug 2008
- LocationRochester NY
- Veteran Field #1St. Jude Donor '09 thru '26
Liked:6,543 Times in 3,208 Posts
Was aware of a wobble on the fan belt, figured it was a loose bolt or two. Had some time just now and started poking around, fan bolts seem tight, etc. Fired it up, it idles nice and smooth.....looked at things while in motion - AND THE !@#$% BALANCER AND PULLEY ARE DOING THE WOBBLING!
Where do I start looking, what do I have going on here? I took a video and saved to my computer but it's an MP4 which the forum won't accept. I'm not on YouTube, what's the best way to post it?
Dad's '66 427
close
- Member SinceJan 2018
- LocationBellevue, WA
- Veteran Field #12023 C2 of the Year Finalist - Modified
- Veteran Field #22020 C2 of the Year Finalist - Unmodified
Liked:2,222 Times in 855 Posts
PM sent...... if you can send me the MP4, I can get it on Youtube to post.....
R66
close
- Member SinceNov 2015
- LocationReally Central IL Illinois
Liked:2,644 Times in 1,756 Posts
Engine? Horsepower?
Does it have a bolt in the end of the crank and is it tight?
Is the outer ring on the balancer moving around - rubber deteriorated?
Correct woodruff keys in the crank?
Sheave / pulley correctly indexed?
Railroadman
close
Believe I'm missing one of the bolts holding the balancer on, possibly overlooked that on assembly. Going to remove a second bolt to determine size and grade. Hoping it's as simple as loosening the alternator to remove belt tension, installing all bolts anbd re-torquing them all.
327/300 block originally, I have it derated to 250hp. Will advise more in a bit. Thjanks!
Nowhere Man
close
- Member SinceFeb 2003
- LocationSitting in his Nowhere land Hanover Pa
- Veteran Field #12024 C2 of the Year Finalist - Unmodified
- Veteran Field #22015 C2 of Year Finalist
Liked:9,422 Times in 6,299 Posts
It wasent until 66 or 67 or maybe later that the base engines ballancer was only a press fit SHP cranks where drilled and tapped for a bolt
TAlvarez
close
- Member SinceAug 2021
- LocationSacramento, Ca
Liked:993 Times in 485 Posts
Quote:
I think you are referring to the bolts that fasten the crankshaft pulley to the harmonic balancer. The harmonic balancer itself typically doesn't have a retaining bolt into the crankshaft on a 250 or 300 HP engine. The higher horsepower engines had a bolt into the crankshaft to retain the harmonic balancer. I would first remove the belts, make sure the pulley is bolted securely to the balancer and then see if you can feel any play (looseness) with the fit of the balancer to the crankshaft. There should be NONE. If there is, you'll need to remove the balancer to inspect the condition of it's bore and keyway, the condition of the crankshaft snout and the Woodruff key and keyway. Also, check that the outer ring on the harmonic balancer isn't separating from the inner hub. The vulcanized rubber that attaches the two components is well known to break down over time.Originally Posted by Railroadman
Believe I'm missing one of the bolts holding the balancer on.
Ted
Railroadman
close
Pulley to balancer bolts are all at 60 ft/lbs. Wobble remains. Removed belt, ran it briefly and wobble remains. Dad's 66 427 will post a 4 second video for me when time permits.'
At this point I'm agreeing with the suggestions the balancer itself may be the culprit.
Dad's '66 427
close
ExploreLooks like it's delaminating. Pretty easy swap. I rather do this task on a C2 any day of the week compared to a C5.....that's a PITA!
Tampa Jerry
close
- Member SinceAug 2005
- LocationTemple Terrace Florida
Liked:1,973 Times in 1,365 Posts
I agree. Looks like the balancer is coming apart. Don't run the engine. Pull it apart. You may need a puller. They are cheap at Harbor Freight or you may be able to rent one for free at your local auto store like Advance Auto, Auto Zone etc. If you want to keep the original, send it out to Damper Dudes or the Damper Doctor in CA. Inspect the crank snout and measure it with a micrometer to see if it has degraded. There is a kit available to dress up the crank. Very lucky that it did not come apart and take out your hood, radiator or you, if you were near it with the hood open. Good luck. Jerry
Railroadman
close
Quote:
That was my next question. I have a twice-postponed date for alignment and inspection, a week from tomorrow. I could resist the urge to go for a ride, but was going to ask about on and off the trailer a couple times and into the shop for the work. I'm hearing don't even think about it. Originally Posted by Tampa Jerry
Don't run the engine. Very lucky that it did not come apart and take out your hood, radiator or you, if you were near it with the hood open. Good luck. Jerry
Tampa Jerry
close
Remember what Dirty Harry said. Do you feel lucky? The damper companies usually turn them around in a few days. Jerry
SJW
close
- Member SinceMay 2005
- LocationCentral Maryland
Liked:2,279 Times in 1,365 Posts
Confirm whether or not there's a center bolt securing the damper to the crank. If so, confirm that it's tight. If no bolt, confirm whether or not the crank snout is drilled for one. If it is drilled, take care to not bugger the threads with a puller as you remove the damper.
Live well,
SJW
Live well,
SJW
Railroadman
close
Quote:
Yeah, with this project, "lucky" isn't even in my vocabulary any more! Originally Posted by Tampa Jerry
]Remember what Dirty Harry said. Do you feel lucky?
Not going to turn the key till this is resolved.I'm not going for judging, ZIP has them for under $100. Can have it on its way tomorrow.
Crank is not drilled for center bolt. I cannot cause ANY wiggle of the balancer by using my hands to yank or wiggle.
Does not appear to be working its way off the crank. But, the paint on the rubber part of the balancer does not look disturbed, no flexing there?
Factoid
close
- Member SinceJul 2018
- LocationSan Antonio, TX/Mahopac, NY
- Veteran Field #12026 Restomod of the Year Winner
- Veteran Field #22024 Corvette of the Year Finalist - Modified
- Veteran Field #32024 Corvette of the Year Finalist - Unmodified
- Veteran Field #42023 C7 of the Year Winner - Modified
Liked:8,414 Times in 4,029 Posts
Looking at the video, I agree it is the HB that is bad. Easy fix!
Nowhere Man
close
local auto parts stores will have them tooOriginally Posted by Railroadman
Railroadman
close
Thanks Keith, will check FLAPS. I'm taking stuff off now.
Nowhere Man
close
Quote:
even though the one you need fits millions of SBC cars and trucks I highly doubt any parts store will have one in stock. But should be able to get you one the next day Originally Posted by Railroadman
Railroadman
close
Quote:
Yeah, and I have had situations where the store's computer said a given part would not fit my vehicle, when I knew it did. Bought it anyway and it did fit. Originally Posted by Nowhere Man
Here's the front of the one that's there now. I don't see any signs of the rubber being distorted or coming apart. Same on other side. I suppose at this point I pull this one off and replace anyway?
Railroadman;
There is a tool; guide, drill and tap to drill and tap the crankshaft in situation. There is a YT video of this being done on a 63. You will need a puller to remove the balancer; install is difficult because you have to use blunt force to install, and swinging a hammer in the front of the engine with limited space is difficult. Heating the balancer is risky as the elastic bond can be compromised. Keep us informed as you proceed.
Aloha,
Rene'
Aloha,
Rene'
