i made a shifktnob for the automatic transmission
Old Yesterday | 12:14 PM
Frost_CA's Avatar
Frost_CA
3rd Gear
Default i made a shifktnob for the automatic transmission
i didn't like the oem shiftknob, actually i hated it, so i designed this replacement that fits without any modification to the boot or the shaft.
it's in 3 pieces, you lock the base with a m4 screw to the shaft, then insert the button, then screw in the top part, done.
it's printed it in ABS, sanded a little and spraypainted, it's still a beta but works with no issue, the goal is to have it machined in alluminium for a better finish.
here's the3d model, feel free to try it, modify it, change it, upgrade it and then post the result.
Old Yesterday | 12:36 PM
jcgunn's Avatar
jcgunn
Old Yesterday | 06:06 PM
hyperv6's Avatar
hyperv6
Any idea of wrapping in leather to remove the printed look?
Old Yesterday | 10:34 PM
Nice effort and I bet it will look much better in aluminum.
Old Yesterday | 10:39 PM
Smoken1's Avatar
Smoken1
I would think that an aluminum one would get really toasty in the summer
Old Today | 04:58 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
If I was going to swap out my shifter ****, I'd probably go with one of the aftermarket ball ***** that eliminate the button (you push the whole **** down instead). However, this is interesting and pretty well done. It will definitely look a lot better in metal as opposed to 3D printed plastic. Have you considered black anodized aluminum rather than polished? I think that would look better. As mentioned though, any metal shift **** is going to get HOT.
To i made a shifktnob for the automatic transmission
