C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
FS: Radiator Hardware Combo Kit
Old Yesterday | 04:43 PM
CADbrian's Avatar
CADbrian
Default Radiator Hardware Combo Kit
I'm selling some of the parts that were removed from my car over the past 5.5 years. All the hardware you see in the kit below is presumed to be repro (maybe some of it is original?) and is priced accordingly, was removed from my car (1967 L36), and replaced with known original hardware. I can't guarantee every nut, bolt, and washer are original assembly-line installed hardware because my car was restored in 2007/2008 under a prior owner, so you'll have to consult your judging guide to know if these parts are "correct" for your car (if you car about that). While some of the parts below might be a little crusty, they are all serviceable and can be made presentable with minimal effort. Some of the parts were polished up and made to look pretty for these pictures. You get everything you see in the photos below for one price $35 shipped to CONUS.
I can't possibly watch my Corvette Forum messages inbox which quickly fills up because it's out of space, so the first person to say "I'll take it" (or something like that) ON / IN THIS THREAD is the buyer. Then we can contact each other and work out the rest. I can do paypal, check, cash, money order, zelle, etc.; can not do venmo. If you have questions about anything please ask below. Thanks for looking.
Included in this combo kit are the following:
1. fan shroud to radiator support bolts & lock washers
2. top fan shroud to radiator support center bolt & lock washer (missing a plain washer)
3. radiator support to frame mounting bolts, lock washers, and thick plain washers
4. fan blade assembly to fan clutch muts & lock washers
5. water pump bypass hose
Old Yesterday | 04:48 PM
CADbrian's Avatar
CADbrian
Here are the pix and more info for the fan shroud to radiator support bolts & lock washers (item #1):
Length: 0.75 inch under the head of the bolt
Thread: #5/16-18
Finish: zinc (probably)
Bolt head: 1/2 inch
Old Yesterday | 04:57 PM
CADbrian's Avatar
CADbrian
Here are the pix and more info for the top fan shroud to radiator support center bolt & lock washer (missing a plain washer) (item #2):
Length: 7/8 inch under the head of the bolt
Thread: #5/16-18
Bolt head: 1/2 inch hex head
This head looks original to me
Old Yesterday | 05:01 PM
CADbrian's Avatar
CADbrian
Here are the pix and more info for the radiator support to frame mounting bolts, lock washers, and thick plain washers (item #3):
Length: 1.75 inch under the head of the bolt
Thread: #7/16-14
Bolt head: 5/8 inch hex head
Old Yesterday | 05:06 PM
CADbrian's Avatar
CADbrian
Here are the pix and more info for the fan blade assembly to fan clutch nuts & lock washers (item #4):
Thread: #5/16-24
Width: 1/2 inch hex nut
Old Yesterday | 05:10 PM
CADbrian's Avatar
CADbrian
Here are the pix for the water pump bypass hose (item #5):
If you look closely you can see yellow printing under the orange paint
To Radiator Hardware Combo Kit
